Chain tensioner
Thanks
p.s. from what i understand the old style timing dampener is discontinued and has been replaced with the tensioner, thats what sdparts.com says anyway, my engine builder recomended and runs one on all his as well
http://forum.grrrr8.net/showthread.p...nsioner+broken
Now this dont mean every LS3 tensioner will fail as with everything else on the internet you hear more about the problem ones than the thousands that are fine. I just chose to revert back to a simpler setup with the C5R chain from Katech my motor is going to see it's share of abuse.
I thought they were there just to keep the chain tight for higher mileage motors.I really hate having a problem with an item that was questionable on whether it was going to help a motor and then it breaks.I imagine there are a lot of big power Gen IIIs out there that are not running tensioners.I'm building a twin turbo 403 and figure I won't be putting more then 50,000 miles on it.If I do get that far i would have no problem putting in a new chain.Plus the new double roller chains should out last the stock chain.I've built a lot of high HP Grand Nationals and on most of those motors we leave the factory tensioner out and the motors hold up real well.Still on the fence on this one.
Thanks for your comments.
