Oil pump drive gear?
Old 06-01-2009, 09:18 PM
DreamKA's Avatar
Default Oil pump drive gear?
Purchased a 2x roller timing set and need to remove the oil pump drive gear. What tool do I use to remove it? I have tried all of my pullers and none of them work to grab that sucker. How do I properly re-install it? I'm sure there's some kind of special tool to use or a tool i'm just not thinking of.
Any help is much appreciated.
Thank You
Mike
Old 06-04-2009, 12:45 AM
racecar's Avatar
It's just a very light press fit, and there is the key. If you can tap a screwdriver in behind it and pry it forward 1/8", then it will go easier.
Old 06-06-2009, 09:49 PM
DreamKA's Avatar
I had a prybar on that sucker and I can't get it to move. I'm a little nervous about tapping a screwdriver behind it. Maybe i'll have to go give it a tap.... How does everyone remove these things?
Help please?!?
Old 06-07-2009, 04:33 AM
WhiteRhino's Avatar
I do the screw driver and tap it on both sides, till it frees up. I use a huge socket to tap it back on.
Old 06-07-2009, 09:16 AM
DreamKA's Avatar
Default 6.0
Does this screwdriver method work with the 6.0 truck engine? The oil pump drive gear and crank timing gear are all one piece on the 6.0 is this the same as the ls1,2,3,6 etc???
I'm installing the rollmaster 2x timing setup and noticed that the oil pump drive gear and crank gear are seperate pieces maybe thats just because it has adjustable timing?
Old 06-07-2009, 12:19 PM
DreamKA's Avatar
Default 2 Jaw Puller
So I went out to the auto parts store and bought a 2 jaw puller knowing it wouldn't fit behind the sprocket.
I then cut down the fingers on the puller so it would just fit behind the sprocket.
This sucker is on there so tight that it broke one of the fingers off instead of pulling off the drive gear/sprocket!
Someone has got to be able to help me.
PLEASE HELP!!! I BEG OF YOU!!!
Thanks
Mike
Old 06-08-2009, 09:52 PM
DreamKA's Avatar
ttt........... All these experienced people and no answer yet hmmm..... Am I missing something?
Old 06-08-2009, 11:01 PM
68 RS Convertible's Avatar
I say whack it with the BFH (Big ****** Hammer)!! I've only disassembled and reassembled one of these things and my oil pump gear drive just slide off of the crank snout. Prehaps try renting a decent three jaw puller to get the bottom timing gear off. If memory serves me correct the oil pump gear drive and lower timing gear are two seperate pieces, same as all the other LS based engines. Did you try and tap a screwdriver between the timing gear and pump gear? Your not going to hurt that part of the crank, its not like a bearing surface.
Old 06-09-2009, 01:03 AM
WhiteRhino's Avatar
I have a 1 piece Rollermaster crank timing gear/oil drive. Like I said above, I did just use a medium sized screwdriver and wacked it with a hammer a few times. Moving the screwdriver from one side to the other. I was using a 12lb mini sledge. After a couple wacks. it came right off. I've done it that was a couple of times. I can't think of any other way to get it off. I have pullers as well. But like you seen. None of them work.
Old 06-09-2009, 05:40 AM
redhotev1's Avatar
Try a hand held torch on gear and then the screwdriver.Becarful installing I have split a gear or two on stock cranks.
Old 06-10-2009, 09:38 PM
Notmyvette's Avatar
I guess the motors in the car? If not you can prob get a long steel drift (I have an old crowbar I cut the hook end off of) and could knock it off but prob not with the oil pan on or if its in the car so forget that.
I would try heating it up and shoving something in between the back of the timing gear to try and budge it forward....alternating spots by turning the crank so it doesnt bind up.
Old 06-10-2009, 10:12 PM
DreamKA's Avatar
Default drive gear
The engine is actually out and in my shed. I don't really understand how i'm supposed to hit the drive gear. The main bearing caps and engine block are kinda in the way of hitting the drive gear to slide it off. I've got to try a couple more things tomorrow.
Thanks all!
Old 06-11-2009, 04:35 AM
vettenuts's Avatar
There is a special tool for this (from the auction site), it is less that $15. Why not just buy the tool as using other methods could result in unwanted damage.
Old 06-11-2009, 06:53 AM
DreamKA's Avatar
Default I knew it
I knew there was a special tool of some sort out there for this job. When you say the auction site what are you referencing? The search has begun. Thank you so much! That is truly what I was looking for.
Thanks again!
Mike
Old 06-11-2009, 11:12 AM
vettenuts's Avatar
Thanks again!
Mike
I have the tool number at home if you need it. It is Kent-Moore and the auction site is fleabay.
Old 06-12-2009, 05:24 PM
DreamKA's Avatar
So what is this tool's part number? I can't seem to find it. call me useless lol but i'm terrible with searching for stuff like this I can never seem to find it.
Thanks again!
Mike
Old 06-12-2009, 06:14 PM
vettenuts's Avatar
Thanks again!
Mike
Here you go: Link
You will need a large steering wheel type puller (see my photo) to use the tool, but you should be able to rent that from Autozone.
Old 06-12-2009, 08:31 PM
DreamKA's Avatar
Default Kent moore!!!!!
TOOL HAS BEEN PURCHASED!!!
ALRIGHT we're good to go thanks to the good people again at LS1TECH!!!!
thank you EVERYONE FOR YOUR INPUT!!!
Much appreciated!
Mike
Old 11-23-2020, 02:48 PM
booboo37's Avatar
That link don't work no more......i need a new link please...
Old 11-23-2020, 07:37 PM
Received 3,113 Likes on 2,428 Posts
WHAT?? It's ONLY been 11 years....
Quick Reply: Oil pump drive gear?
