Oil pump FAILURE
Old Jun 4, 2009 | 09:01 AM
JVetthead's Avatar
Default Oil pump FAILURE
Glad I rigged low pressure light....
Old Jun 4, 2009 | 03:03 PM
05gto60's Avatar
more info please...
Old Jun 4, 2009 | 03:05 PM
LS1BLKSS's Avatar
Banned Village Idiot
yesss give us the 411!!! is that stock??
Old Jun 4, 2009 | 03:11 PM
dlove's Avatar
I don't think it ran dry. I think you sucked something into it. How does the pickup look?
Also what was the application of the car? RPM?
Old Jun 4, 2009 | 08:41 PM
JVetthead's Avatar
Built 427 based on wet sump LS7 block.. Dedicated road race car, less than 8 hrs on engine but lives only in the top half of the RPM range.. Pick up and o-ring all looked good. This engine was rigged with external oil pressure regulator and allways had a high freq. chatter that I thought was the regulator but guess it was the pump.. Going dry sump.. After going thru the engine for a cleanup that is......
Old Jun 5, 2009 | 03:18 AM
racecar's Avatar
Never heard of an external regulator. Was it mis-aligned, or did the constant pressure create a hydraulic lock that caused it to burst.
Old Jun 5, 2009 | 06:03 AM
05gto60's Avatar
what pump was that?
Old Jun 5, 2009 | 08:18 AM
JVetthead's Avatar
It was a Mellings pump... rigged with the internal regulator blocked, the oil exits the block at the left front gallery plug, goes to ext. regulator-filter-cooler, then back in the block at the rear gallery plug..
