LS3 and 8k RPM
Old Jun 10, 2009 | 02:28 PM
v502's Avatar
Question LS3 and 8k RPM
Just thought what do i need to spin LS3 (415-418) to 8k RPM for FI
I like to keep it 14-15 psi and min. of 800rwhp for now
YSI-trim Vortech
Heads ?
Single intake
Callies Magnum Crank
Oliver Rods
Wisco pistons CR # 9.7 - 10
Old Jun 10, 2009 | 02:36 PM
00SS6spd's Avatar
Lots of money, hopes, dreams...
Seriously though, you should really consider going solid roller and aftermarket roller rockers if you want to spin up to 8,000rpm. Your best bet is to call up a reputable engine builder.
Old Jun 10, 2009 | 02:44 PM
BES Stroked Nova's Avatar
what would be the need to spin it that high FI?? can save you lots of time and troubles running the motor below7k, and you can make just as much power...
Old Jun 10, 2009 | 03:23 PM
ss1's Avatar
ss1
Yeah, wow! You won't need to spin the engine to 8000rpm to make 800rwhp with a YSi blower. It's going to be difficult to achieve 8000rpm on a N/A engine, now think about what would happen with the extra 15psi of boost on the valves. I think yo uneed to re-think your goals here.
Old Jun 10, 2009 | 03:31 PM
v502's Avatar
Its a thought only
But i will sure keep at 7K
My goal is 7k with 800rwhp i was only wondering is needed for 8K
Do u think guys the LS3 415 is durable enough to handle 800rwhp daily driven
I was going to take it to 418 but just worried about cylinder walls.
Old Jun 10, 2009 | 04:16 PM
99blancoSS's Avatar
A good amount of money was the right answer.
We can help you achieve your goals, HKE engines hit 8500-9500 rpms when built for it but your looking at an expensive build up.
So is it really just a topic of conversation or are you prepared to spend the serious money it will take to hit that goal?
Old Jun 10, 2009 | 07:13 PM
v502's Avatar
Do u think the engine 8K - 9K Rpm will handle the abuse from being driven daily.
Thats why i only said 8k but i like to hear what's available it only depends if its worth the money to spend on.
Original Plan was LS3 427 with Darton sleeves but i changed cause its wasn't recommended and risky and i don't want to refresh every year.
Now i think if i keep it at 415 will be best.
Old Jun 10, 2009 | 07:27 PM
99blancoSS's Avatar
Well 8-9k... how often does it see that? Whats the application? Its all about money but whats the real goal here?
800 rwhp with the ability to go to 1000?
Old Jun 10, 2009 | 08:15 PM
v502's Avatar
Yeah something like that.
Its going to be for a corvette and mostly street driven by that i mean every day and get some races out of it on weekends.
I just worried about reliability.
Old Jun 11, 2009 | 12:59 AM
00SS6spd's Avatar
We aren't ricers, and these aren't Hondas dude... Revving to 8,000-9,000 should not be a "goal" for your project. It should be a by-product of an application-specific custom engine build, not a deciding factor in how to build it.
Old Jun 11, 2009 | 04:44 AM
v502's Avatar
9000 RPM will be extreme for daily driver.
No i want to keep it between 7000-7500 Rpm
My problem is every time i shift gear at 6500 i am out of supercharger power band(4000RPM) it take a moment to start going again.
How good will be LS7 heads on LS3 415?
Is it worth the money or should get CNC ls3 heads?
Old Jun 11, 2009 | 01:30 PM
mikeith's Avatar
for FI the ls7's will definately be a benefit. its just one of those "is it worth it to you" gains. its not a huge difference but it will be noticable
Old Jun 11, 2009 | 01:41 PM
Tuner@Straightline's Avatar
My NA stock displacement LS6 hits 7500rpm no problem, peak HP was at 712xrpm or so, peak torque was at 6100rpm. Problem with reving past 7600rpm is the computer starts to loose crank signal.
Old Jun 11, 2009 | 03:33 PM
00SS6spd's Avatar
Do you know if it's any better with the different reluctor wheel in the newer motors? And if you don't mind my asking what lifters were you using, Morels? I wouldn't want to go much past 7,200 with hydraulic lifters, and especially at 7,500+ rpm I'd want to be going with a solid roller setup.
Old Jun 11, 2009 | 03:37 PM
THENASCAR's Avatar
i was actually wondering the same thing, i wonder if the 24x or the 52x would be best for higher rpm signal strength. of course something out around the 7500-8500 is borderline not drivable safely on the street. but would be neet to see
Old Jun 12, 2009 | 09:59 AM
The cars that were running into this problem were 24x reluctor set up, not sure if the 52x reluctors are any better.
I'm using Comp Cam 875-16 lifters.
Old Jun 12, 2009 | 01:26 PM
ringram's Avatar
The older ecu was limited by its clock speed. I think you will find the newer ones are much faster and more powerful.
Think 8086xt vs Pentium4 etc.
