DCR Calculation Help (Piston Selection Issue)
L92 heads, 64cc
head gasket: .051 & 4.180 (or 4.160)
bore: 4.080
stroke: 4.00
IVC: 71 deg @ .006
cam: 232-238, 595-605, 114 LSA, ICL 110
.010 or .015 dish piston?
Thank You All!
Last edited by Philly-Goat; Jun 23, 2009 at 05:16 PM. Reason: Left out piston info & wrong IVC
Yeah, I mixxed the IVO (31) & IVC (71) numbers up...it's correct now (71 deg) on the initial thread and that is @ .006.
Also, I am shoot for a SCR of 11.4 or 11.5, but it's still depends upon the piston itself (dished, flat or domed). Yes?
Thank you for all of your help!
Here is the calculation with a flat top piston:
Here is the calculation with the piston top adjusted for 11.5 SCR:
Let me know if you want me to make any adjustments anywhere.
I wasn't expecting that, WOW!
Anyway, I was told that the piston would be .008 out of the hole and this is a dish piston. Also, please adjust the piston cc to 10 first & 15 the second time. I'm still trying to get to 8.3 to 8.5DRC, but not lower than 8.1! I am open to suggestion to get, if you have any recommendations (i.e. change head gasket or larger cam)? I really appreciate all of your help!
15cc dish:
