Fast 102mm Intake--Real Results --NO BS
#63
1 Post
Don't really think this is a surprise.![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
But maybe with the bigger TB and you doing an all-out port job on the intake you will get some results.
After taking a closer look, you picked up some between 3800 and 4200 and then again at 6700-6900.
Curious as to the difference in conditions between the 2 runs?
Thanks for the HONEST numbers. Glad to see the numbers unfudged to post facts, vs fudged to sell intakes that as is don't make power across the board vs the ported ls7 intake.
#64
1 Post
*********SORRY FOR THE SMALL HIJACK************
#65
+1 I see some visible gains. 10+ rwhp picked up in certain spots but only for brief times. Can't wait to see the fully ported version and larger TB.
#66
This is more info than most were looking for I expect, but invaluable info when seeking to understand the reality behind flow numbers. If the intake charge does not flow with sufficient velocity to move through the entire "air pump" that our motors are, peak power cannot be realized.
As for the FAST 102 being worthwhile, independant testing such as Ragin's and company will be the real test and we may find that adding the 100mm TB may not do the trick.....but with the proper heads, cam profile, and exhaust as long as there is not a bottle neck or restriction in any of the key areas, I suspect we will see these make good power. If not, it will be a first for the FAST line of intake manifolds.![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#69
FWIW
http://forums.corvetteforum.com/c6-z...g-reading.html
Made some good gains, but...........
Still not an apples to apples comparison because when they tested the LS7 intake they ran stock LS7 injectors. When they switched to the FAST they also switched the injectors to 60lbers.
#70
Proof that we will buy f'n ANYTHING if it's HYPED enough and we have to wait long enough. Nothing like selling a product and going to production b4 it's proven. And don't expect the all the vendors to come clean, some are, after all, in bed w/ comp. Some just get a better shafting than others.
#71
1 Post
WOW and I thought I was the only black sheep around here !!!!!!!!!!!!!
You got ***** to post it bro. Sponsor bashing is not permitted, ask me how I know.
#75
Thanks, what would we all do without your valuable knowledge.
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#78
Restricted User
That thread in the corvette forums was inconclusive at best. I'm sticking with thiss thread as "The Best Real World Results to Date".
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#79
1 Post
I'll bring it up with the guys at Vengeance on my next visit. If money keeps coming in I may be going back for susupension and something extra just for me. Not saying just yet. LOL.
#80
Well............this is how i see it
Ls1 design was basic, Then they did the ls6. TADA, THEEEN we started porting the ls6!
THEEEEN aftermarket companies made intakes and we ported those!!
All the while GM was (Im almost POSITIVE) scooping up these "Ported intakes" and studing them and figuring out what makes them tick .
Fast forward from the first ls style intake through 1o plus years and countless versions from GM and aftermarket pieces, Gm makes the ls7
The way i see it is how many times can you revise one single design (ls style intake) before it really cant get any better?
