LSA crank in LS2 block?
The LS2 already has Pistons and rods, looking at the LSA crank as a cheap upgrade...
Thanks
Mike
Yo. Figured it out. Yes, you could use this in an LS2 but,...you..or, If I were to use the LSA crank I would have to get a different flywheel.
For me, since I think I found my favorite clutch already(exo skel)....I don't think I would change to a six bolt crank, if I knew I had to get rid of my clutch setup.
Would have to find anoter flywheel to work with my current exoskel disc's and presureplate.
