06 TB SS LS2 into 02 SS
Ok I know the intake/oil pan/ and acc. have to be changed...the question thats got me is....the motor is out of a 06 TB SS..the reluctor wheel needs to be changed...RIGHT!!! cause the shop is tellin me its fine!!!!! the swap is the same as doing the L76/LS3-LQ4/Lq9 swaps right...
A quick way to tell if it needs to be changed is by checking the reluctor wheel itself to see If it has 2 rows of teeth. If it does have 2 rows of teeth on it, it's a 24x ls1 style reluctor wheel and it's what you need.
The 58x reluctor wheels will only have 1 set of teeth. (Not 2 rows of teeth)
If for any reason you end up with a 58x reluctor wheel and you can't get a 24x reluctor wheel you can always buy a converter box from Lingenfelter for around $250.00.
Also, the reluctor wheel has to be pressed onto and off of the crankshaft in case you didn't know. Most shops will charge roughly $75.00-$125.00 to do this.
Hope that helps....
James
