Lsa
The g8 makes kiddie power compared to its comparable relatives. so I really don't know...haha.
Edit: the heads are diff.
On the other hand the l92 heads are the same as the ls3 heads...I think
I though about doing this to a CTS-V as well but then again I would have to spend another 2-3 Grand on a damn rear. I just want a 10 sec car. I mean I've seen 9 sec TBSS. so it can be done. they had a built LSx in it as well. I am wondering if an LSx 454 CTS-V can accomplish that and beat the snot out of Terminator Cobras and what not.
Cams are a completely diff. story...I just through that one out there. I probably would use something completely different than that, but it all depends on what I want.
The main difference between the motors is 12cubes (6.0 vs. 6.2), the AFM system, and cam shaft. The cam in the L76 is .472"/.476", that's the main reason the G8 is so underpowered.
PS
The L76 uses a solid intake valve, the LS3 uses the hollow stem.
Gen III and GEN IV's normally use a 6 bolt pattern at the end of the crank.
LSA uses an 8 bolt pattern, and LS9 uses a 9 bolt pattern.
Why? no one at GM has said why, but that is how the motor how they did them.
But if the car your put'n the motor in is a manual then the LSA clutch is a dual clutch similar to the LS9's....
The ci difference in the L76 and LS3 seems to be about a 15-20hp difference, everything else being equal.
I'll be cam swapping this fall.
especially if you are planning on dumping more cash on heads and other mods after spending some serious coin getting the lsa in your car.
you could make a serious monster on your own in a similar configuration.
any LS block with a good head and cam set up (do some research on blower cams) and a supercharger will put down gobs of HP!
ive got a vortech blower on my LT1 and i thought for a long time that centrifugal blowers were the cat's meow, but after reading a lot, id really like to have more boost and torque down low. while the roots blowers aren't as effecient at higher rpms, i really like how much they flow at low rpms.
but of course, if i had no boundaries of smog tests and money.....TURBO is the best way to go IMHO. and you cannot beat the sound of a spooling turbo!!!!
