408 or 418???
Old Jul 29, 2009 | 10:23 PM
MelScrilla's Avatar
Originally Posted by Jimmy P
I would go with the 418, just get it built right. I understand that aluminum isn't quite as strong as a iron block, but there are plenty of aluminum blocks out there making big power.
+1 IMHO part of the allure of the LS series engines is to be able to make power like the Gen 1 bigblock with less cubes and less weight. If you go iron you'll only pickup about 80 to 100 pounds which equals about .10 in the 1/4, but I would rather have the aluminum if you aren't going to be a hardcore dragracer, shooting big shots on 2 or 3 stages.
In NC the guys at RPM used a LS7 block in their nitrous racecar for a couple of seasons with no problem, and now their upgrading to a world warhawk block which is also aluminum.
Old Jul 30, 2009 | 05:15 PM
THE LAST Z's Avatar
Im gonna say 408 since youll be spraying & then pick a N/A cam that will also work well with spray. If you were staying all motor, then go with the 418. The difference of 10 cubes isnt much at all, so I would go with a 427 ls3 if I was going N/A.
Old Jul 30, 2009 | 05:19 PM
z28mccrory's Avatar
Im going to throw a curve ball into this conversation...
You can have a 418 with an iron block also... by going with a longer stroke.
My 418 is a 4.03" bore iron block, with a 4.10" crank.
Old Jul 30, 2009 | 05:28 PM
WKMCD's Avatar
FWIW: The extra bore on the LS3/L92 block unshrouds the exhaust valve a little more on the L92/LS3 heads.
Old Jul 30, 2009 | 05:38 PM
99blancoSS's Avatar
Yep but we don't recommend a power add with it. We offer that as well but it seems most guys want to spray so he 4" stroke stuff is more desirable
Old Jul 30, 2009 | 05:41 PM
z28mccrory's Avatar
It will do just fine for spray. The motor was planned with the intent to spray 300-350hp of nitrous.
Not to name drop or nut hug... but Tony Bischof is the one who specd it out... and if you know who that is, you know he has more than enough experience to be able to determine that.
Old Jul 30, 2009 | 06:54 PM
99blancoSS's Avatar
LOL, yea and we see people spray and boost big amounts on bigger strokes, its just not something we advise doing with our customers. I didn't say it couldn't be done.
Old Aug 3, 2009 | 05:11 PM
DramaBull's Avatar
What about a small shot like a 150?
Old Aug 7, 2009 | 09:57 PM
MelScrilla's Avatar
"If you plan on using over a 150 HP shot of nitrous or more than 10 psi of boost via forced induction, we recommend our TSP 402 cid LS2/L76. The 4.00" stroke will allow for lowered ring lands and a thicker piston top to take the abuse of power-adders."
Quoted straight from the TSP website so a 150 shot would be right on the borderline but it seems safe according to TSP.
The only thing about power adders is that they get addictive and once you shoot the 150 and get to say a 10.17, you know your going to want to hit it with 200 to put you into the 9's.
Old Aug 8, 2009 | 12:42 AM
z28mccrory's Avatar
You will be fine... to that amount and much more.
Old Aug 18, 2009 | 06:20 PM
Dom's Avatar
Dom
How good are those 418 aluminum blocks at handling boost. Has anyone blown one with a SC like a D1SC? I'm just wondering what the upper limits of LS3 blocks are.
