Racetronix knock sensor extension harness
Old Jul 21, 2009 | 10:04 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Is there any type of external visual indicator allowing one identify which type of knock sensor is in a motor before actually removing the intake?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Jul 21, 2009 | 10:14 PM
JFM-jr's Avatar
I did manage to snap this pic of the knock sensor with my cellphone it has the part number on it.
These were probably used in 97&98 model years only. If I were using the original 1999 knock sensors that cam with my car I would not have run into this issue. Thing is I looked on the Racetronix site and it lists this harness good for 97-04 LS1's. As we now see this is not the case.
Old Jul 21, 2009 | 10:17 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
I see them during engine swaps, but the only 50/50 indication I can give is they were only equipped along with perimeter bolt heads/valve covers. I've come across both designs in 1998 F-bodies, usually end up replacing the older ones with the 2nd design anyway.
Old Jul 21, 2009 | 10:18 PM
Racetronix's Avatar
LS1TECH Sponsor
So w/o looking up the VIN there is no way of knowing forsure?
__________________
>WEB SITE<
Old Jul 21, 2009 | 10:26 PM
-Joseph-'s Avatar
I don't even think the VIN helps... I don't think GM documents mid-year changes for the parts counter guys.
Edit: I just remembered that my brother's 1998 T/A had the older style, I can grab his VIN tomorrow and call Scoggin to verify. I believe his was an early model.
Old Jul 22, 2009 | 01:12 AM
Racetronix's Avatar
LS1TECH Sponsor
It is unfortunate that we can not rely on GM's publications. It is very odd given the number of harnesses we have sold that we have not run into this before. There are two other vendors which make a similar product and they also list them as LS1 harnesses w/o any mention of alternate connector types.
Hopefully the VIN can help narrow this down.
__________________
>WEB SITE<
Old Jul 22, 2009 | 07:53 AM
BigDB's Avatar
This is very true I myself have the Caspers harnes (no offense racetronics its what my local speed shop had) and it has the same connector. Looked on their site and its the only one available, thought I was goin nuts. I also am glad im not the only one who has run into this.
Old Jul 22, 2009 | 09:19 AM
JFM-jr's Avatar
Well to the credit of Racetronix I have also bought their cam sensor (LS1 to LS2) and fuel pump with the hotwire kit. All three items fit perfect and were as easy as it can get to use.
Old Jul 24, 2009 | 07:06 AM
Haans249's Avatar
This part shows up on gmpartsdirect.com - 10456222
