Racetronix knock sensor extension harness
You need to drill and tap-
Hope that helps
"1997-2004 LS1 to LS2 Knock Sensor Relocation Harness
This harness allows the single-wire LS1 knock sensors located on top of the LS1 manifold to be relocated on both sides of the LS2 block and plugged into the factory LS1 PCM harness. It has the perfect added length and thermal protection required to be routed near hot exhaust manifolds. Compatible with the PCM harness in LS1 Corvette and F-Body cars."
Rob.
Need to extend wires.
Buy Racetronix Extenders.
Plug into PCM wire--AOK.
Other end will not plug into 1999 LS1 knock sensor.
Look at the pictures,seems like a Ractronix mix up
Shane
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
You need the 99-04 Gen III knock sensors to use the extension harness. Although I'd be tempted to just forget about using knock sensors anyway.
Don't need no stinking knock sensor's!!!!!!!
Learn something new everyday.
The single cavity 150 series connector you show here is used on 3.8L V6 f-body cars only. See the attached image.
If someone can produce evidence that a LS1 motor came with different knock sensors / connectors please send us pics / info.
We would like to ask JFM-jr if his car was originally a V6 model?
Thanks.
>WEB SITE<
We will contact GM parts tomorrow to see if there is a different part listing for knock sensors based on LS1 y-body model year.
>WEB SITE<
I remember even having to specify the design when replacing the KS and harness while I still worked at Scoggin-Dickey.
Google brought this up:
http://www.statracing.com/oem-replac...t=Knock+Sensor
