L92 Head Flow Results
The flow numbers are in for my heads. These numbers are on the stock valve job and with stock GM LS3 valves.
The Head Shop here in Houston did the porting. Sean and Jerry are the techs.
The Intake 158.1 @ .200 The Exhaust 114.0 @ .200
221.5@ .300 160.1 @ .300
280.4 @ .400 199.1 @ .400
312.0 @ .500 226.5 @ .500
337.2 @ .600 243.6 @ .600
346.0 @ .700 250.0 @ .700
WE are going to use REV valves. When the valves come in the shop will do the valve job. May have even better #s. Its been a long process the car has been down almost a year. This engine should be a torque monster with the L76 intake on it.
My cam came in last week. I ordered it from FTI. The duration is in the 240+ range on the intake and 250+ on the exhaust. The lift is less then I thought it would be. It was ground by Comp. It' s a kit with PAC 1521 springs and Ti retainers. Ed said it will make power from 3800- 6800 RPM and is for a long runner type intake. I'm hoping it will be a torque monster. It should work well with the L76 that I have. Come on Fast 102!!! I really wanted to rev this engine but it looks like that is not going to happen. I began looking at the Vic Jr, but this came is not optimized for it.
Oh yea I would like to thank Sean and Jerry at The Head Shop for seeing this project through. It has been a learning experience for all. Give these guys a call for any of your engine building needs.
