Reluctors
Old Aug 5, 2009 | 01:40 PM
MENTHOLISCOLD's Avatar
Default Reluctors
Can you press off a 58 tooth reluctor and press on a 24 tooth wheel? If not can a pcm be progammed to accept a different tooth count? Trying to keep costs low. I know they can be serviced, but not sure if compatable.
Old Aug 5, 2009 | 01:59 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
if you already have the crank out of the engine, then it is not too costly. the reluctor does have to be indexed though. then change to the correct sensor.
if the engine is not taken apart. then you can use the 58X-24X converter.....
we have those on hand...
Old Aug 5, 2009 | 02:34 PM
Can you give me a part # please. Thanks for your help
Old Aug 5, 2009 | 02:35 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
please be more specific...lol. pn for the wheel, the sensor, or the conversion box
Old Aug 5, 2009 | 02:46 PM
conversion box.
Old Aug 6, 2009 | 03:38 AM
rsz288's Avatar
The reluctors heat exapand off/heat shrink fit on and preferably use a tool to align/index. ECM's not changeable at this point (exception probably MAST unit), or as John @ Scoggin mentions, a Lingenfelter 58X to 24X convertor.
