i need opinions on this setup im going with
Old Aug 6, 2009 | 12:36 AM
Daryn's Avatar
Formerly darynC-10/23/10
Default i need opinions on this setup im going with
okay so im putting a l92 in my truck. coming from a 5.3......
the motor has slightly ported heads , milled .040 with double springs....
the cam is a 230/242 .600 110 lsa... but the cam is going...
i plan on putting an ls2 cam 204/211 .525 lift i got for a great deal...
now the only reason i am swapping cams is because this cam is way to big for a DD
what do u guys think about the ls2 cam in the l92? im sure i would still see a good gain over a stock cam with the head work.... but i dont think it will hit as hard up top, which i will be shifting around 6,000 -6,200
this is going with a ss3600 and 3.73's ... 5,200lbs weight
