408 build
Old Aug 11, 2009 | 02:32 PM
Jwright41's Avatar
Default 408 build
I have been reading on these threads for a while and was wondering what the real price would be for this built. Im talking every bolt, gasket, oil pan, etc, pretty much everything that comes with it and needed for it. Will probably ask the help of a friend so that labor wont kill me - just pay him something on the side. Will probably see about selling the old engine. Right now has only 42,000 on it.
Goal - around 500rwhp and 470rwtq. Car would be more of a weekend car. Something that would be good to drive at the same time or would that be asking too much?
Any information would be helpful.
Old Aug 11, 2009 | 02:40 PM
the_merv's Avatar
What do you plan on using from your car?
Old Aug 11, 2009 | 02:41 PM
99blancoSS's Avatar
I'll pm you with some pricing info, you have a few options.
Old Aug 11, 2009 | 02:51 PM
Jwright41's Avatar
Anything that I could use from my car with that motor. Wasnt too sure if you could use anything from the LS1 to that new motor. Guess that is why I ask the pros!!!
Old Aug 11, 2009 | 02:52 PM
mrgoodwrenchSS's Avatar
I'm in the process of building my N/A 408. I've been doing this with a budget in mind. I've got most of it together, With the right parts and machine work I would say you can easily make a 500 horse 408 for under $5,000
Old Aug 11, 2009 | 02:55 PM
basically about all you can use from your car is the hardware, such as the covers and cover bolts, everything internal you would want to buy new. If you are really on a budget you could re-use your cylinder heads and buy an assembled short-block, i'm not sure what youre after.
Old Aug 11, 2009 | 03:00 PM
Jwright41's Avatar
Thanks for the info MrgoodwrenchSS. Was looking at an assembled block and new heads and cam. Does the LS6 intake fit on this 408? Think that it does from what I have read.
Old Aug 11, 2009 | 03:02 PM
99blancoSS's Avatar
the intake is related to your head choice and you have a few head choices with your power goals in mind
Old Aug 11, 2009 | 03:12 PM
Jwright41's Avatar
Awesome. PM me with a few choices with those. I got your last one and appreciate the info in it.
Old Aug 11, 2009 | 03:14 PM
the_merv's Avatar
Yea your Covers and Oil Pan, Starter, and Accessories is about all you can use. That and all the Sensors.
Old Aug 11, 2009 | 04:04 PM
boostnificent's Avatar
under $5000? really? i've been looking at rotating assemblies and they cost half of that. then an LS3 block bare and with out machining is $1300. where are you getting parts so cheap?
Old Aug 11, 2009 | 04:16 PM
smok'nZ's Avatar
MASS seller approved
my buddy made 502 with a 408 patriot stage III's texas giant cam, and an LS6 intake, ported tb,6 speed 10 bolt
thats cheapall of it was off the shelf parts
