Oil pressure LOW at high temps
Old Sep 4, 2009 | 01:57 AM
05gto60's Avatar
GMs "rule of thumb" is 8PSI per 1000RPMs
Old Sep 5, 2009 | 07:11 PM
Slowhawk's Avatar
LS1Tech Sponsor
We never run anything under a 40 weight oil in out built motors.Ussually a 10w/40. The 30 weight is just too thin and when oil temp gets high it can break down.
What your seeing with the low pressure when hot is the oil temp getting high.I've seen Vette's running 190 coolant temps but the oil is hitting 250 degree's on the hot days.Some hit 280-290 after some good runs.
I'd switch to some thicker oil and see how it does.
Old Sep 5, 2009 | 10:51 PM
RyanSws6's Avatar
I've been wondering too. I've it similar and have that high pitch too BUT I thought its an idle pulley bearing. I've got M1 10 40. I want it thicker. I will say I was SUPER carefull when I put in the tube. I even modded the Windtray to have the tube in the stock location. Thing is I'm going to do a cam swap and will replace the pump jus in case. I do have a new LS6 pump.
I am worried, I've got maybe 300 miles on it.
60 psi cold
40-45 2k hot
35-38 idle hot
Not happy with it, my LT1 is better than this.
Old Sep 6, 2009 | 01:47 AM
racecar's Avatar
My LS6 Ported pump = 60 cold at 2000, 50 warm at WOT, 40 warm idle.
Stick with one brand / one weight of oil, go with 10/40.
Old Sep 6, 2009 | 09:33 PM
Monte4ever's Avatar
I'm new to the LS1 family of engines but I know one thing for sure 30 to 40PSI of hot oil pressure is perfect. Even 25PSI hot is good. Most of you are use to the stock .0008 - .0015 bearing clearances that gives those high oil presure readings and allows you to run that thin 0w 30 oil. However, when the clearances are opened up to say .002 - .0025 your hot idle presure will drop some and you most-likely will need to run a heavier oil; something like 10-40 or maybe even 20w 50.
Old Sep 6, 2009 | 10:10 PM
Deeavi's Avatar
I only run 10w-40 Synthetic oil in my LS motors. These are high performance engines that need oil that can stand up to stress better. Synthetics also flow better in cold weather. Try it for awhile and see how it performs. If you are still having pressure problems after running the synthetic, then check your pump and/or O-Ring for problems.
Old Sep 7, 2009 | 12:32 AM
LS6427's Avatar
So nice to hear someone else say this. I've been running 20w50 in my 427ci for 6+ years and its friggin great. Engine loves it. Pressures are great. 124,000 miles.
People think I'm crazy for running such thick oil. They just don't get it.
On very hot days the oil definitely gets thin and the pressures drop down, but on the gas its always jacked up to around 40psi crusing steady.
Old Sep 7, 2009 | 12:38 AM
LS6427's Avatar
Originally Posted by LSGunZ28
If you feel this is credible advice, then I will take your word for it..
Im just wasnt sure.. But is it normal for the psi to remain at near 40-45psi at WOT even as high as 5000rpms? (when its really hot?)
what psi should I be seeing at 6500rpm, when really hot?
Well, the guages in our cars aren't the greatest anyway.
You say "when really hot".....45psi isn't bad at 5,000rpm. If your psi didn't climb at all from whatever it is at idle, then you'd have some trouble.
There's absolutely nothing wrong with trying 20w50...thats what I use. Been using it in my 427ci for 6+ years, its perfect.
Give it a try.
Old Sep 7, 2009 | 06:47 AM
jermzz's Avatar
im sory, but a 20psi idle is not normal on any ls motor. My stock 100k motor idled at 35psi hot, heads and cam.
Bought a 427, cold idle was 50, hot idle was 20, ended up needing barings, had to rebuild it.
The most important question to ask yourself is if the oil pressure has stayed the same thoughout the life of the motor, or if it's fluctuated.
if your **** has always banged 20psi hot from day 1, then you're probably ok, i say thats stupid low, but if it's working then whatever.
If it used to be 35-40 hot idle and now its 20hot idle, i'd venture to say you're due for a rebuild Ive never seen any built stroker ls6 pumped get 20psi hot idle. ever.
Old Sep 7, 2009 | 03:38 PM
slowrollin93's Avatar
Also agree on the 20 psi at idle being terrible. I just had a buddy go through this **** were his oil was that at idle. He spun two main bearings. With my 5.3 150k miles on it still never got under 40psi and im in central texas. Now with my ls1 stock pump and about 15k miles I still never get under 40 psi even when the truck is hot as hell and passed the 210 mark on the temp gauge. And at around 3000 rmps my oil pressure is around 80 psi. Somethin is wrong and the sooner you realize it and stop driving it the less damage you will do. It is not that hard to check out the o ring or change the pump out. Even with a stock pump you got kickin around somewere to see what the pressure does. And I run snytec 10w30 with these pressures in 100+ degrees days and after wot.
Old Sep 7, 2009 | 06:07 PM
Monte4ever's Avatar
I agree that if a motor starts its life making 40+psi oil pressure hot and down the road it starts making less then yes, something is wrong. But most built motors have wider clearances and often have less pressure. My old BBChevy had 18psi hot oil pressure and stayed that way for years with no problem.
Old Sep 9, 2009 | 07:30 PM
  #32
LSGunZ28's Avatar
Give it a try.
Ive been meaning to reply to a few other people out there, but I dont have a lot of time right now..
But to replay back to you.. Id wanna say, It did climb from abou 22psi to 45psi...
So I guess it is ok... I guess its just hot and Im putting a lot of load on the engine..
But I want really paying attention, but I was looking the other day from the corner of my eye and, it does "seem" to stay at about 45psi from 3500 til 5500.. and it didnt seem like it climbed up gradually.. so I just am kind of worried for that also,.. and I will make sure of this, soon, when I get a chance....
but if a lot of people are saying 22psi or so is fine , after the oil gets hot, then, Im not troubled too much anymore..
Old Sep 17, 2009 | 12:49 AM
  #33
LSGunZ28's Avatar
update:
The oil pressure gauge was fluctuating a bit today..
When it was at 22-25 psi and I went WOT, it climbed to about 40psi, but seemed to quickly go back to 35psi then again quickly back to 40-45psi....
Also, as I mentioned before, some oil is getting consumed. I was the low oil light come on later on today..
Old Oct 19, 2009 | 07:01 PM
  #34
Fifedogg's Avatar
update:
I bet you were starving the motor for oil...If you add oil to the correct amount it will probably take care of this problem. This happened to me a few times before on my stock motor. All I had to do was add oil and it stopped happening.
I have similar oil pressure as you when using 10-30 Mobil 1 or Pennzoil Platinum. Though mine goes up to about 50 @ WOT when the motor is really warm. My low will also be at arount 20-25 at idle. Considering we both got our motors from TSP that might mean they are normally like this...Have you tried contacting them and asking about this?
I have tried Pennzoil vr1 20-50 and it does seem to add more pressure to the motor when hot but almost seems like there is just too much pressure when it is cold (the guage almost all the way to the top) I ended up mixing 3 quarts 0-50's and 3 quarts 20-50's to make an even 10w-50w. It seems to work pretty good at keeping my oil pressure within the correct limits or so I think considering I'm using the old stock oil pressure sending unit and judging off the stock guage.
Old Oct 20, 2009 | 05:43 PM
  #35
v8newb's Avatar
Originally Posted by AKMac
I had the exact same problem. It ended up being the oil pump o-ring on the pick up tube. It destroyed the block.
me too- by the time I put an oil pressure gauge on my car it was too late-
the culprit:
Old Sep 13, 2017 | 11:13 AM
  #36
ENV MN's Avatar
You'll know you have a problem when you hit the pedal for a hard acceleration run and the oil pressure drops slightly then comes back up but doesn't really climb much more than where it was when you hit the pedal.
What would this mean is wrong with the engine? This is exactly what my car is doing. I have a 2012 CTSV wagon with this problem. and a few other odd issues but I noticed this one recently along with some odd metallic rattling upon revving hard.
Old Sep 13, 2017 | 11:24 AM
  #37
Odd metallic rattling when accelerating could be preignition, AKA pinging. After enough of this, your lower end falls apart, which might explain oil pressure fluctuations.
Old Sep 13, 2017 | 12:27 PM
  #38
ENV MN's Avatar
Thanks for the response.
Any idea as to why I would be having pinging? It literally happens on command. I am in neutral, rev the engine hard to about 4500rpm let off and hear what sounds like a kid playing with keys or a necklace jingling near the front passenger side of the engine.
Old Sep 13, 2017 | 12:43 PM
  #39
Wait; it pings when accelerating, OR when you let off?
Old Sep 13, 2017 | 09:06 PM
  #40
Hypforlife32's Avatar
put 20w-50 vr1 in it. as long as your psi increases as soon as you touch the throttle then your good.
Sounds like your motor was built a little on the loose side.
mine is .003 on the rods and .0025-0028 on the mains. plannig on running 20w-50 this time around. Previous builder put everything to stock specs and said run 5w-30 lmao. 1200hp motor. great idea. at the time i didnt know any better. stupid me
