Announcing a new LS-series "How-to" publication:
In a few weeks (after you have spent some time with the manual) can you do me a favor and write a little review or rating on amazon.com?
I'll update my threads when it is available on amazon anyway, hopefully they keep the intro pricing.
Good work!
Thanks!
I'm sure you're ecstatic about the book!
I'm going to have to pick this thing up!
What type of vehicle do you own?
I would recommend setting up a shop to discharge and recharge your A/C, that way you can just unbolt the lines and remove the A/C condensor out of the way completely for the camshaft itself. I've moved them enough before without recovering the refrigerant but it is a little harder to work around.
The LS2 is actually not too bad of a camshaft for boost - you also don't want or need to go too crazy with blower cams, but something in the mid 22x's for intake duration and lower 23x's for exhaust should do well on a wide LSA (115ish) for something that you see a good gain from, many sponsors can get you into an ideal camshaft for what you want. You may notice a drop in boost PSI, but this is due to less restriction in the engine, and more air into the cylinders - if you want more boost, pulley swap time.
