Ouch... (Jesel rocker arm failure)
Sorry to see yours fail so early..You and I didn't have alot of options with these heads. I hope you find the reason why these took a dump....
Check the underside of the rockers. If I remember correctly there is a protrusion that once much above stock lift will contact the base. These rockers won't take the lift you are running. Contact "Arkay99" for the details, he ran into this on his motor and ended up with Yella Terra's instead until he figures out how he can fix the Jesel's. What he found was the rocker was being stopped by the stand prior to achieving full lift, which that being the case, you likely have an overstress issue.
http://jesel.com/index.php?categoryid=24
Blaming the rocker right away without knowing the rest of the story and how they are setup is ridiculous. I've seen tons of trashed stock stuff and especially the HS modded stuff recently with welded needle bearings and grossly eroded tips and yet haven't really had any issues either with any of our own stuff using any of these Jesel or stock rockers.
To the OP: Look closely at your rocker bottom, the photo above (the third to the last one in your first post) shows marks similar to those Roger posted in the link.
Because the exhaust valve is still open as the intake starts to open there is never any cylinder pressure on the intake while it is opening.
As you know the exhaust does fight the cylinder pressure as it opens. This is increased wtih a nitrous application because of the increased cylinder pressure.
Most of the valvetrain failures I have seen were a result of loss of control of the valve. A weak spring or aggressive cam profile can promote the loss of control. While testing components on the Spin Tron I saw what the "hammer" effect did to components.
I would look at the RPM range verses the spring pressure. Also be sure that the pushrod is not flexing and pounding the rocker.
Oh, I have used the Jesel products for many years on several different combinations. I have never had a problem even when I was killing seats and valves from the valve float.
Good luck!
Robin
Good luck!
Robin
thanks Robin. So it looks like the bottom of my rockers had been in contact with the rocker stand rails. This must have happened back when I had the huge cam. I figure the rocker arms clearanced themselves and then most likely didn't hit after I put the new (smaller) cam in. You can see the marks where they were rubbing. The marks between the 5 and 7 are from the top of the bolts that sit directly below the rockers.
I drug my feet for a while then got in touch with Jesel. Rob Remesi from Jesel returned my emails and was very nice. I told them about the interference issues and the problems that others have experienced. I also expressed the fact that I understood that this failure could have very well happened due to a general installation error. He swiftly reccomended that I send the rocker arms in for inspection and he would replace the rocker bodies free of charge. I am very pleased with the service I received from Jesel and would recommend them to anyone. These showed up around 7 business days after I shipped them out.
