Ouch... (Jesel rocker arm failure)
Old Nov 3, 2009 | 11:11 PM
  #41
KCFormula's Avatar
Originally Posted by Pwebbz28
I went with T&D and got junk. Geometry was so far off the pushrods were moving towards the intake during the arc. In not so many words T&D rep said the rockers are great for anything but a race motor. Sent them back and never got a full refund(they were only used on the dyno for a fraction of time until we noticed what was happening) Went with DRE rockers are everything is beautiful to 8500 RPM.
Wow, *knock on wood, My T&Ds have been solid.
I considered switching to a Jessel Mohawk but figured why fix it if it ain't broke.
Old Nov 4, 2009 | 11:35 AM
  #42
racer7088's Avatar
Thumbs up to Jesel for fixing that.
Old Nov 10, 2009 | 03:56 AM
  #43
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I remember reading this back when it first happened. Have you clearanced the new stands to potentially fix this issue?
Got to give vettenuts some kudos on nailing it.
Old Oct 26, 2011 | 02:00 PM
  #44
1SAWB's Avatar
Originally Posted by pwebbz28
i went with t&d and got junk. Geometry was so far off the pushrods were moving towards the intake during the arc. In not so many words t&d rep said the rockers are great for anything but a race motor. Sent them back and never got a full refund(they were only used on the dyno for a fraction of time until we noticed what was happening) went with dre rockers are everything is beautiful to 8500 rpm.
so let me understand this correctly....please correct me if i'm wrong....you purchased a set of rocker's and installed them. Didn't look to see if there was any issues with fitment with your combination. .i.e. Pushrod diameter, lifter height, etc. Attempted to dyno this disaster and then your pissed that the manufaturer wouldn't give you full credit ........wow !! Sound's to me your lucky you got any credit at all. I will honestly say that all my dealing's with t&d have been flawless including custom set's that have been built... To each there own i guess
Old Oct 26, 2011 | 02:08 PM
  #45
racer7088's Avatar
Arrow
The rockers he had were junk. We got stuck with some too. They were not designed correctly. They were made to fit under a valvcover at the expense of geometry. I have never had an issue with the normal race T and Ds but these LSx models that he had are not built right. The pushrod cup was relocated too far down and pushrod side geometry was horrible. Taking these off and going Jesel was night and day. Again the other T and Ds I've used have been flawless.
Old Oct 26, 2011 | 03:53 PM
  #46
MeentSS02's Avatar
Kleeborp the Moderator™
So let me get this straight...you dug up a post from 2009 and posted in it as your first post?
Yes, I'm being an *******, but your post didn't add any value to the discussion, hence my comment.
Old Oct 26, 2011 | 07:09 PM
  #47
noice's Avatar
Well since this thread is back alive again, I saw a set of aluminum Jesel Rockers similar to these fail. Granted the guy was running nearly 800lb open. Way more than he should have, also the ones that didn't fail started to sieze up the rotating parts in the rocker.
Old Oct 27, 2011 | 04:32 PM
  #48
noice's Avatar
These were off a BBC. This is what happens when you run way too much pressure. The bearing it pivots on is shot as well.
Not broke yet
Broke
