any 408 stroker advice?
especially the part of the money you were willing to spend on the rotating assembly.
maybe you see it as going back to the drawing board as far as the components is concerned, but really, you are not. you end up saving a little money, and you will have the cubic inches you wanted to begin with. hope this makes sense, and good luck!
blancoSS and TSP gave you some ideas and price ranges i think are really good.
and, yes, you can go with one of those options, and still sell the LS1 to offset some of the expense. btw, that is what i did/am doing.
check my sig. How much RWHP do you want and how much do you have to spend. That is the basis for all you decisions. Do this right or you will be sorry.
also, your rearend should easily hold over 600rwhp with a locker and 35 spline axels in a 9".
my .02 GO 408 with a mid level rotating assy. bang for buck best option and l92 heads + a little n20
i would make sure whoever helps you build it relizes its a gen3 late model block not a 70's 350 or you will be in trouble
