Another 402 build...
Old Sep 25, 2009 | 12:40 PM
gtslo88's Avatar
Default Another 402 build...
Should be able to pull the trigger on this build come early November. Been doing a lot of research just want to make sure every thing was sound and would be the best performing package. I plan on having this motor built through HKE here in Houston, I have seen many successes with their engine builds.
My goals are to make 550 rwhp on motor and over 7 on the gas.
I will use my ls2 block
-Compstar 4" Crank
-compstar connecting rods
-Wiseco Pistons(not sure which ones)
+all ARP Bolts, and all the bearings needed.
Will I Be able to continue to use the cam in my sig? or would i be better off going with somthing a little bigger.
Will this setup be able to hold up to a 200 shot no problem?(will probably be a 150 or 175) shot will most likely be ran off of a plate until i have the funds for a proper direct port
I also plan on buying a set of AFR 225cc heads with the 72 chamber, is this the best way to go with the 402?
Fuel system and drivetrain will be taken care of, just wanted to see how the motor will hold up and if my goals seemed pretty achievable
Old Sep 25, 2009 | 12:54 PM
blu byu EH's Avatar
Your cam is too small, and your comp. needs to be 11.5 to 1, and 550 hp will be hard but more like 530ish hp is more like it. Is your fast ported? Have fun with the new build.
Old Sep 25, 2009 | 02:27 PM
gtslo88's Avatar
The Fast92 is ported. What kind of specs should i look for if this cam is too small?
Also which pistons/any other internals would be best with the amount of nitrous i want to run
Old Sep 26, 2009 | 06:10 PM
blu byu EH's Avatar
I would run -8 pistons, I would do a n20 cam. Contact vengeance and they can help you out on the specs.
Old Sep 27, 2009 | 10:02 AM
99blancoSS's Avatar
When it comes time to build it get a hold of me and we will set you up. We distribute HKE engines.
Callies crank and rods and Wiseco pistons with custom pins and Hell Fire ring, ARP mainstuds will be the bottom end. AFR 225's are a great choice, TFS 235's would be good too as well as a few other top ends. Stock rockers are fine with the HS rebuild or we would use Yella Terra Ultra lites. Manton custom pushrod, Morel lifters, N-Motion double roller, Melling HV OP is our usual build up. We can upgrade or down grade it's your call.
The most important thing to an engine build is not the parts but who builds it. You can use a $5000 rotating assembly and it will break apart just as easy as a $1800 assembly if it's put together wrong, the tune is off or the compression is to high....
