cam for LS2 in 67 camaro?
Old Oct 7, 2009 | 01:15 PM
STAR's Avatar
Default cam for LS2 in 67 camaro?
Swapping an ls2 motor into a 67 camaro and would like to change the cam for sound and power! The motor will be basically stock with bolts ons.
Cold air intake
Long tube headers
True dual exhaust
Tune
The transmission will be a stock 4L60 and currently stock converter. The power will be transfered to a 12 bolt with 4.10 gears.
Looking to acheive good driveabilty with a noticeable idle, but don't want any bucking or surging!
Was thinking something along the lines of:
220/226 114
226/230 112
What do you guys think? Or what might you suggest?
Old Oct 7, 2009 | 01:45 PM
someday's Avatar
how about the 226/230, on a 114... and drop the 4.10's for a more reasonable 3.42 set... a mild 2600 converter would really wake it up while being decent on the highway with the 3.42's...
Old Oct 7, 2009 | 06:08 PM
69LT1Bird's Avatar
Go check Comp Cams new Thumpr line they sound like what you are after.
Old Oct 7, 2009 | 08:58 PM
67SS509's Avatar
10 Second Truck Club
Comp Thumper series is the perfect cam for you!
