6.0 aluminum block ?
Old Oct 12, 2009 | 04:50 PM
boogeyman's Avatar
Default 6.0 aluminum block ?
ive got a 05 TBSS w 6.0 aluminum block thats exploded is the 6.0 iron block interchangeable w the aluminum block and what would need to be done to get it to work ? need help from the LS gods ?
Old Oct 12, 2009 | 06:34 PM
SteelmanLS1's Avatar
Iron 6.0L would be basically a direct replacement for you. Shane
Old Oct 13, 2009 | 05:13 AM
427's Avatar
427
The drivers side front of the block is missing two tapped holes, one can be added. Not sure if your TBSS even needs these. If the block is older the head bolts will be a different length. The cam sensor from the LS2 can be added on the iron block and should work with a few minor differences.
Kurt
Old Oct 13, 2009 | 07:16 AM
Shawn @ VA Speed's Avatar
you also need to run an ls1 style vally cover-the ls2 is different
