ls2 block
Old Oct 18, 2009 | 02:11 PM
sixt9er's Avatar
LS6427-I said, if you look closely, "YOU SHOULD NOT..." The key word being "should". One can do what he/she wants and what he/she could afford. I was giving the OP the "general consensus" of what I personally have been hearing for the past few years. Not to say that I am right and you are wrong or you are right and I am wrong, I am just stating information for the OP to use or not. There are BETTER choices for the OP to use. For example, stock pistons can be use for a boosted application, probably not the BEST choice for such a thing, but you could get away with it to a certain PSI level. LS2 blocks can be used as well. I probably would not use it simply because a IRON block is available and stronger and I would want piece of mind with HP levels that high. Anyhow, enough with beating the dead horse. Lets move forward!
