ls7 lifter question?
Old Oct 23, 2009 | 04:35 AM
denali-08's Avatar
Default ls7 lifter question?
well I have a 2008 gmc single cab with a 6.2 engine, it have gone trought 6 stock lifters, will the ls7 solve my problem or should I buy another ones. btw I am shifting at 6800 rpm thanks
Old Oct 23, 2009 | 06:27 AM
69LT1Bird's Avatar
You may want to give some more detail, something sounds very wrong to be eating up lifters like that.
Old Oct 23, 2009 | 06:59 AM
Gordon0652's Avatar
Thinking the same...
Old Oct 23, 2009 | 12:59 PM
denali-08's Avatar
well the first time that lifters broke was bacause the cam was not thighten as it should be so the cam moved while I was driving and 3 lifters broke, i replaced them with 5.3 engine lifters, so maybe 5.3 lifters are not good .
Old Oct 23, 2009 | 07:32 PM
denali-08's Avatar
bump!!
Old Oct 23, 2009 | 07:40 PM
DVS99TRANS's Avatar
Technically the LS7 lifters are now stock. They don't produce stock LS1 lifters anymore. I don't know if the 5.3 and LS1s had the same lifters although I assume they would. Throw the LS7 lifters at it and call it a day. It may be a good idea to get new pushrods while your at it. The LS7 lifter cup sits roughly .06 higher than stock.
Old Oct 23, 2009 | 09:22 PM
cutlass_455's Avatar
Are the lifters turning in the trays?? Does that sound like something that lines up with your problem?? Maybe consider replacing them too.
Old Oct 25, 2009 | 06:26 AM
muayyadf1's Avatar
You might have too much preload that eats your lifters. Check pushrod length
