Big N/A horse power guys please step in
Old 10-28-2009, 04:03 PM
  #61
JUNK's Avatar
Settle in on a cam and choose compression to work with overlap....that is, the more overlap, the more compression it will tolerate, hell, it will even need it. A small cam with 2 deg of overlap would surely detonate with pump gas, but with 40 plus degrees, u better have at least 12.1 or it will be lazy on the bottom end. It's not about compression or cams, it's about COMBINATIONS
Old 10-28-2009, 05:10 PM
  #62
02402RAMAIR's Avatar
I agree.
Old 10-28-2009, 07:38 PM
  #63
Bandit28's Avatar
Arrow
Originally Posted by LS6427
That 500ci ERL would be simply AWESOME if it wasn't so damn expensive. Its just way too much money, if you plan to use the regular top end stuff (LS7 heads, LS7 intake, FAST intakes...etc..) all you're gonna get is an engine with just a little bit more than a run of the mill built 427ci-440ci.
There's a guy on here with one that makes only 650 RWHP, thats a joke for a 500ci engine. Its gonna be a very fast car, no doubt...but for 500ci.....lol
You can build a 454ci LSX for half the money or less....and make MORE than 650 RWHP with the right top end and not spend near $25,000.
Its 100%, all about the intake and heads. Cubes are meaningless if they can't breath.
"There's no replacement for displacement".....well displacement means nothing with the right top end.
ONLY 650 HP? LOL that is a alot for a street engine. Considering the fact no one has tried to really push a superdeck II further than a "street engine" sooooo where are you going with this...? ERL has made around 650 on their dyno. The 500 CI from ERL has basically what would be considered a stock camshaft for a 500 inch motor, turns less than 7K RPM. GMPP L92's something around 10.5:1
VS
454 with radical cam(prolly wont idle well), aftermarket cylinder heads ported above and beyond some production L92 castings. big dollar intake manifold and Im sure it sees more than 6200 RPM. And there you have it, MAYBE it might see 650hp on an engine dyno.
LOL I really CANNOT EFFING WAIT to see the day they really do a MAX EFFORT 500 CI at ERL Performance!!
Old 10-29-2009, 07:27 AM
  #64
VS
My question is why in the heck would ERL build a 500ci motor and dyno it with basically stock top end parts? Built to the hilt bottom and stock top? WTH! That gives us no idea what the thing can do other than guess.
What really sucks is the header issue. Custom headers?
Try putting a tall deck in a Vette. I am sure the intake won't clear the cowl. It's all up on it right now with a stock deck!
I would love to build one but I don't want to be the guinea pig.
Old 10-29-2009, 09:26 AM
  #65
Bandit28's Avatar
LOL they have one in a C5!!! clears just fine!! FATORY HOOD! Im not sure what they did for exhaust but I know what I would do! The intake sits about 3/4" higher than a stock LS engine.
Old 10-29-2009, 10:41 AM
  #66
The hood would not be the issue. It's the cowl. Not much room there. If they have done it then I guess it will clear. I am curious to know about the headers and the accessories. The power steering bracket bolts to the head so it should move it some what but shouldn't cause a problem. I would think it would need custom headers.
Old 10-29-2009, 10:48 AM
  #67
Bandit28's Avatar
Well custom to me isnt that hard I go to my buddys fab shop borrow whatever I need or take him to lunch maybe give him $40 bucks for supplies and WAM custom whatever I want... I believe ERL had a complete Mach pulley system and I also believe they are trying to taylor these engines to the older Corvette croud, with that being said I want one with more compression, better induction, and making around twice what it is now on power!
Old 10-29-2009, 10:55 AM
  #68
Bandit28's Avatar
I saw it before they went out on the Power Tour this year it didnt look like they had to fab on the cowl... I would call them up with any questions.
Old 10-29-2009, 10:57 AM
  #69
Was it ERL who did the install?
Old 10-29-2009, 10:58 AM
  #70
Stage7's Avatar
They actually did not need custom headers. They used their engine mount which lowers the engine ~1". The headers fit. The X-pipe needed to be modified, which "sounds" a lot easier to work with than having to modify both headers to fit.
Old 10-29-2009, 11:06 AM
  #71
Bandit28's Avatar
Yes, but it was THEIR car not a customers. They just do machining and assembleing of engines otherwise.
Old 10-29-2009, 11:08 AM
  #72
I would think the issue was the cowl having to lower the engine. With my 2 inch headers there is no room for movement. I had to clearance the tunnel to make mine fit without hitting. I bet they used a 1 3/4 header to make it fit. Will have to call to find out.
Old 10-29-2009, 12:24 PM
  #73
tektrans's Avatar
My personal opinion ( which is worth about 2 cents ) is if that 500ci set up would hold up with a max effort build, they would have done it already OR thay have done a max effort build (under wraps) and it did not hold up. Either way, until it's proven that the set up will hold up under a serious build it's not worth speculating about it. I mean, c'mon-what are they waiting for? You can't effing wait? Why are THEY waiting for? Like people wouldn't be lining up to buy a 500ci LSX if it was a solid base for serious hp??
Would be a badass sonofabitch if it DID hold up-that's for sure!
Old 10-29-2009, 01:10 PM
  #74
LS2 500CI STREET/STRIP
Displacement: 500 CI, 8.2L
Bore x Stroke: 4.200 x 4.500
Compression Ratio: 12:1
Fuel: 93 Octane
Block: LS2 / Ductile Iron Sleeves
Head: LSW ALL PRO Ported (West Coast)
Rockers: Jesel Shaft Rockers (1.8:1)
Crank: Custom Callies Forged
Rods: Custom Carrillo A Beam
Pistons: Custom Wiseco
Camshaft: 248/248 @ .050, 117LSA, 0.660" LIFT
Intake: 102mm ERL
Throttle Body: 102mm ERL Electronic
POWER: 700 HP
TORQUE: 650 FT-LBS
This has bad *** heads, 12.1 compression, 102mm T/B, and so on. It's not MAX effort but is pretty damn healthy. Numbers don't look that promising for a build of this magnitude.I am sure with a nice sheet metal intake and a good size camshaft it would pick up considerably. RPM would be the limiting factor I would think.
Old 10-29-2009, 01:25 PM
  #75
Stage7's Avatar
That cam is tame for that size motor. Kumar dyno'd 650/610 w/ported GM Ls7 heads and hydraulic roller on an ERL 500ci. I don't remember the size of the cam, but he said it idled like a baby.
Old 10-29-2009, 01:31 PM
  #76
Fuel: 93 Octane
Intake: 102mm ERL
POWER: 700 HP
TORQUE: 650 FT-LBS
That motor is 12 to 1. OH ****. That thing is going to burn down on 93. 11.3 MAX on the street. lol I could resist.
Old 10-29-2009, 03:15 PM
  #77
Bandit28's Avatar
You could be right tek, but I doubt you are. Think about it not evenyone can even afford their street motor. So how many would be able to pay for the high cost of the top end on that monster. Because IMHO that 500 needs a sheet metal intake with twin dominators, similar to a prostockers induction. And even though the badest heads on the market prolly wont let it breath like it needs to it is still worth a shot! And I bet you it will happen in the near future when someone comes along with enough money to foot the bill... but only time will tell.
Old 10-29-2009, 03:19 PM
  #78
Bandit28's Avatar
Fuel: 93 Octane
Intake: 102mm ERL
POWER: 700 HP
TORQUE: 650 FT-LBS
Sounds like they have bumped up the compression and changed out the valve train and cylinder heads and picked up some power...
Old 10-29-2009, 04:56 PM
  #79
LT-4Play's Avatar
Why hasn't anyone mentioned LG's 500ci set-up?
https://ls1tech.com/forums/dynamomet...663-611-a.html
Old 10-30-2009, 09:17 AM
  #80
Quick Reply: Big N/A horse power guys please step in
