LS9 head stud kits now in stock
Old 11-10-2009, 01:11 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Default LS9 head stud kits now in stock
We now have LS9 head stud kits which are a direct replacement for the OEM head bolt. Includes studs, nuts, washers and required lube. $299.99
http://store.katechengines.com/Product203
Old 11-10-2009, 01:23 PM
NemeSS's Avatar
what advantages do these fasteners have over the current ARP ls head studs??
the ls9 seem to be significantly higher priced than ARP
Old 11-10-2009, 01:45 PM
LS1TECH Sponsor
Current ARP LS head studs do not fit the LS9 due to it's unique size. We had to make this head stud kit up.
Old 11-10-2009, 02:04 PM
Big_Bird_WS6's Avatar
so the arp does not fit the LS9 block or head?
Old 11-10-2009, 02:09 PM
LS1TECH Sponsor
Correct
Old 11-10-2009, 07:22 PM
Formerly darynC-10/23/10
Daryn's Avatar
whats so special about the ls9 block? aint it a 6.2 ?
Old 11-10-2009, 07:30 PM
Petraszewsky's Avatar
X2 I was under the impression that the block was the same as the LS3 but it has oil squirters along with the chamfered skirts for less windage...So ARP studs will work on a LS3 block but not the LS9 block.???
Old 11-10-2009, 07:37 PM
Daryn's Avatar
just read on gmhtp that they use 12mm instead of 11mm ?
Old 11-10-2009, 07:48 PM
LS1TECH Sponsor
The LS9 uses a unique 12mm head bolt found on no other LS engine. They also have piston squirters, billet main caps, optimized bulkhead windows not found on the LS3.
Old 11-10-2009, 07:57 PM
Gotcha...I see now
Old 11-10-2009, 09:33 PM
mtrhead's Avatar
Are LS9 blocks available?
Old 11-10-2009, 10:38 PM
texas94z's Avatar
Good question.
Old 11-10-2009, 10:56 PM
Daryn's Avatar
350$ for a head stud kit is kinda high IMO, but i guess if a guy can spend 130k on a car or 20k on a bare engine, 350$ is chump change
Old 11-11-2009, 02:19 AM
cryer's Avatar
are u guys have cnc program for ls9 heads yet? what kind of flow numbers.
I have a set I am looking to get done
Old 11-11-2009, 09:59 AM
LS1TECH Sponsor
Originally Posted by texas94z
Good question.
Maybe Scoggin Dickey could chime in.
No, we do not.
Old 11-11-2009, 02:09 PM
LS1TECH Sponsor
Well, good news on these kits. The response has been pretty good and the volume may be higher than I originally thought. So, we have been able to increase our volume and reduce the cost per piece. We have reduced the retail price to $299.99/set which is the same price as our other head stud kits.
Old 11-11-2009, 02:47 PM
gectek's Avatar
good info
Old 11-11-2009, 02:50 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
I would contact Richard at WCCH for that. They just finished a program on both the LS9 and LSA heads IIRC.
No, we do not.
Availablility on these (bare blocks) looks to be slim to none and slim left town.
Honestly GM has a part number, but there is no price and NO availability.
Old 01-31-2020, 06:51 AM
Floorman279's Avatar
well **** I have a set of 2 lengths custom age. was going to use them on my NA motor because they came with a turbo motor I bought. I should sell them and buy new studs to make a few bucks
Old 01-31-2020, 07:12 AM
bortous's Avatar
Still waiting on some more trolling troll.
Quick Reply: LS9 head stud kits now in stock
