Which Ls3 Cam?
My current set-up is.
Stock bottom end L92
.20 milled heads ls3 valves and smoothed
240/248 .608/612 114lsa old grind comp cam
ported intake and NW92mm tb
Tsp 17/8 headers
powerbond pulley
Lunati 233/247 .577/.597 114lsa
TSP 231/236 .641/615 111lsa
Comp 231/247 .617/624 113lsa
vengence 231/243 .617/624 115+3
I do like the TSP one but I would get it on a 112.
There are 230/234 LS3 cams (Spin's) on CF breaking 500rwhp so you don't need to over do it with LS3's.
I worked on a local car that had a g6x3 from LGM on a set of L92 heads and made really good power. From what Louis said at LGM the g6x3 had increased intake lift and duration (versus the g5x3) to take advantage of the LS3/L92 port design
specs
230 intake on a xfi lobe 612 lift
234 exhaust on a xer lobe 598 lift
114 lsa with 2 degrees advance so 114+2
liknk to thread
http://forums.corvetteforum.com/c6-t...right-now.html
link to video
http://www.youtube.com/watch?v=IfDzSjVn508
fast forward the vid to about half way
230 intake duration on an XFI lobe .612 lift
234 exhaust duration on an XER lobe .598 lift
114 lobe separation angle
2 degrees advance ground in
Comp cams: call and ask to have a custom cam ground (400 bucks) and give them those specs.
