Wiseco vs. Diamond
Old Nov 22, 2009 | 10:13 PM
getusum's Avatar
Arrow Wiseco vs. Diamond
Just wanted to get a few thoughts from the guys that have run both.....My last setup used Wiseco -8cc nitrous pistons and did very well...Currently looking at a new build and my builder is leaning toward the Diamonds...
...Just looking for some insight on the Diamonds..It seems that Diamond has stepped it up with the Ls series and are now offering coated skirts included as well as a few other little things, that they didn't before....
Thanks in advance...
Old Nov 22, 2009 | 10:26 PM
Bandit28's Avatar
IMHO the Diamonds have a better skirt design, the Wiseco's have a little stubby thing. But you cannot argue with what works. I have had them both and they both took a massive beating.
Old Nov 23, 2009 | 07:40 AM
getusum's Avatar
appreciate the info...
Old Nov 23, 2009 | 09:39 AM
1CAMWNDR's Avatar
Wiseco. They come with that smaller skirt to clear all cranks and all 8 pistons will clear the reluctor wheel. Wisecos also come already prepped; no deburring needed by the engine assembler. I have been very pleased with mine.
Old Nov 23, 2009 | 10:05 AM
getusum's Avatar
My Wisecos have been great....Just looking for people using Diamonds, since my builder was leaning towards them....I've been the guy that when something works, stick with it...I'm not a builder, I destroy ****... so I was looking for some different insight..
Old Nov 23, 2009 | 11:01 AM
itsback08's Avatar
i would also like to know witch one is better... as for i'm going to be building a new motor soon
Old Nov 23, 2009 | 01:06 PM
99blancoSS's Avatar
Wiseco offers free coating where you have to pay for it with Diamond. The same piston cost about 150-250 more from Diamond that you can get from Wiseco. We use Wiseco in 99.9% of our builds with no issues ever. Why swap when you had good success? It wont be any better but will cost more.
Old Nov 23, 2009 | 02:02 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We also use Wiseco more often than Diamond. They require less finish work and deburring, have the skirts coated for free, and a big nasty thick top ring land and ring set included standard!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 23, 2009 | 03:04 PM
getusum's Avatar
That's what I was looking for.....Thanks...
Old Nov 23, 2009 | 03:18 PM
TT632's Avatar
Had to clearance the pin boss area on the diamond to clear the reluctor wheel on the last one I did.. It was kind of annoying, but you get used of stuff like that in hot rodding.
Old Nov 23, 2009 | 03:21 PM
sixpack_2_go's Avatar
https://ls1tech.com/forums/generatio...o-pistons.html
this should help
Old Nov 23, 2009 | 05:02 PM
supermouse4's Avatar
Go with Wiseco. A friend has a LS build and has had no issues with Wiseco pistons in any of his other builds.
All of what others have said about Wiseco pistons are true in this thread.
Old Nov 24, 2009 | 11:47 AM
briannutter's Avatar
Look for some additional oversizes and new designs at PRI on Dec. 10. Thanks for your support. -Brian Nutter -Wiseco Automotive.
