LSX Tall Deck blocks are in at SDPC
Old Dec 2, 2009 | 07:09 AM
Stang's Bane's Avatar
Originally Posted by KCS
What's the cylinder length? The std. deck blocks were like 5.50" right?
Fantastic question.
Old Dec 2, 2009 | 08:50 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I missed up there where the part number was posted, it is not the same part number that is in the GMPP catalog and that number will show unavailable. The actual part number is 19244059.
Also, a quick measurement showed the cylinder to be (roughly) a few thousandths over 6"
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 5, 2009 | 02:47 PM
LSX-PWR's Avatar
Do you have any in stock. The reason I ask is because I'll be around your neck of the woods mid Dec and I would like to pick one of these tall decks up.
Old Dec 5, 2009 | 07:11 PM
CalSpeedPerformance's Avatar
4.25" stroke x 4.185 bore with a really long 6.4" Rod...Make a good blower motor.
Old Dec 6, 2009 | 12:52 AM
We definitely have them in stock.
__________________
Old Dec 8, 2009 | 01:43 AM
LSX-PWR's Avatar
Will I need a spacer to make up for the tall deck? The reason I ask is because I have a sheetmetal intake made by Beck and I would still use this intake since I'm using C5r heads.
Old Dec 8, 2009 | 08:07 AM
ATVracr's Avatar
Yes.
If you are having it made they can build it to fit instead of using spacers.
Old Dec 8, 2009 | 11:10 AM
LSX-PWR's Avatar
The intake has been built already. I'll ask Mr. Beck and see if he could modify the intake. If not I'll have another built but instead I'll have one made like the one that's on the SAM orange car.
Old Dec 30, 2009 | 08:18 AM
I have more of these available now! Remember, GM has released their own 6-bolt as-cast LS7 heads, along with several carb style intakes in tall deck versions (with pads for drilling injector bungs if needed)! Just give us a call if you have any questions at all about it, 1-800-456-0211
Jesse, ext 358
__________________
