228r for TBSS
Old Dec 1, 2009 | 01:55 PM
Big_Bird_WS6's Avatar
Default 228r for TBSS
ok my TBss has a LS2. what do i all need to change to make this came work
228/228 588/588
what will my springs take?
should i change push rods
should i change spring retains?
Thanks
D
Old Dec 1, 2009 | 05:30 PM
Bring the Noise's Avatar
The LS2's came with the LS6 springs on solid valves. Replace them with a good set of .600" capable springs.
Stronger Push Rods would help as well.
A torque converter would also be a good idea for that cam.
Also, check in the Trailblazer section for other drive-line upgrades you may need.
There's also retuning the ECM, especially if you pair the cam & spring upgrade with a set of headers and/or a cold air kit.
Old Dec 2, 2009 | 10:08 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
^^He hit pretty much all the points. You'll want a quality torque converter for that one, springs, pushrods, bolt/gasket kit, tune, and of course all the bolt-ons to make this one work well! It's a nice camshaft for that 6.0L and with the proper supporting mods and tune will not kill your torque or make that heavy truck unbearable to drive!
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 2, 2009 | 10:20 AM
JCattSS's Avatar
Headers & a converter would be a real good idea, 32-3600 depending if you want to tow etc. I have something in that neighborhood you, will need springs and pushrods too.
Old Dec 2, 2009 | 08:01 PM
devilsgrin's Avatar
I like my 3200 one of the best mods I did. I did the converter before the cam.
