goat truck motor swap
LS1Tech Sponsor
The 08 will have the 58x tooth reluctor wheel and the 4X cam gear. To make it work with a 24x computer you will need to change the top gear to a 1x and get a 3 bolt cam, as that one may be a single bolt and either change the wheel on the crank or get the lingenfelter converter box. you might want to watch out on that truck engine though. it may have the VVT and DOD, so make sure to look it over first. run the vin if necessary to confirm. its not a huge problem to make it a standard engine, but it will cost a good amount.
