Cam is to big
Old Dec 16, 2009 | 01:39 AM
Mustang Hat'r 2's Avatar
I know the difference. I wouldnt put a little 224 cam in this 418. Ive had 224 in a 346 and it was pretty tam.
Old Dec 26, 2009 | 04:50 PM
LS1ROPER's Avatar
You really need to get with knowledgeable people like Shane from Thunder or let Patrick G spec you a cam you will be happier with the end result IMHO!
Old Dec 26, 2009 | 07:40 PM
Randy WS6's Avatar
I have a LS2 418 and my cam is a Cam Motion 257/266-665/640-114 and i shift at 7200rpms and it keeps pulling. and love nitrous
Old Dec 26, 2009 | 09:52 PM
LSGunZ28's Avatar
Originally Posted by Mustang Hat'r 2
So what would you recommend? I wont spin it more than 6800, its a M6 with 3.90 gears and should weigh about 3500 with me in it. Power can start as low as idle but want it to be really strong from 4k to 6800.
How about a 260/270 on a 110LSA with a 650 lift and the fast ramping lobes. Would that work or should I adjust it? Advance 4 degrees?
Why dont you just ask Patrick G to spec you out a good cam for your setup, if you arent knowledgable to do so yourself.. Its worth it.
