LS2 w/L92 heads
Stock unmilled:
Bore 4
ST = Stroke 3.622
RL = Rod Length 6.098
Number of cylinders 8
Deck Height (how much pistons come out of the hole) -0.01
Piston Dome or Dish (- for a dome + for a dish) 6.7
Compressed Head gasket thickness 0.052
Cylinder Head Chamber Volume 69
Static Compression Ratio 9.84
Dynamic Compresion Ratio 7.81
Rod to Stroke Ratio 1.68
Bore to Stroke Ratio 1.10
.025" milled:
Bore 4
ST = Stroke 3.622
Cylinder Head Chamber Volume 65
Static Compression Ratio 10.28
Dynamic Compresion Ratio 8.15
Hi pressure EFI Walbro 255lph External Fuel Pump
$149.99, Racetronix Fuel Pump F99-FPWH Wiring
Harness, BGK8 Battery Ground Upgrade Kit, PBIC
Pump Booster Connector Set $79.99, 25ft 6AN Braided
Fuel Line for feed and return fuel lines MRG-S256
$94.50,Russell Quick Disconnect 6AN Fitting @ Fuel Rail
$17.65, ACDelco C5 Corvette Fuel Regulator/Filter
Assembly $59.99, Fuel Rail Crossover Braided Line
$19.99, Fuel Rail Front 3/8" NPT Plugs $6.95, 3/8 NPT
to 6AN 90 Deg Fuel Rail Fitting $13.95, 6AN to 3/8NPT
Adapter $3.95, 6AN Female - 6AN Female Coupler
$7.39, (3) 6AN Hose End to 6AN Fitting ($5.88 ea)
$17.64, Fuel Line Hose Mounting Clamps (Set of 10)
$9.95, Fuel Regulator Return Fuel Line Russell Quick
Disconnect 6an fitting $17.65, Tank Return Fitting
90-deg welded into tank $8.50, 6AN fitting for fuel pickup
$8.50
Custom standalone wiring harness for conversion $488.00
67-69 Camaro LS1 Swap 1-3/4" Longtube Headers -Ceramic coated $665.00
Hoses, Electrical, needed parts for
installation, gaskets - Speed Nut U-type 22.70,
Serpentine belt 41.23, $20, Upper Radiator Hose $21.99 Lower Radiator Hose
$12.99, Radiator Hose Clamps $3, O2 Oxygen Sensors
(2) 73.99 each - $147.98, Rubber Hoses $8,
Lokar LS1 Throttle Cable (54.99),
SDPC Conversion Billet Throttle Cable Adapter Mount (99.00)
Custom Built Cold Air Intake Setup: 4"x3.5" 90 deg $199.99
reducing elbow,45 deg 3.5" couplers,intake mount
attachment, 4" & 3.5" stainless hose clamps, 3.5" piping
/w custom sized K&N Filter, black paint /w mass air installed into assembly.
Casper Electronics CEI-108100 (adapter to connect $29.95
85mm mass air and IAT sensor to engine wiring harness) If you are using
an LS1 computor, this bit my *** for 9 months the wiring crosses in the casing so you have to plug it in backwards or the computor will not see the cam. makes for very hard starting.
Parts 85mm Mass Air Sensor *used* ($50)
Additional parts for engine used Coilpacks, $1,000.00
Accessory bracketry, F-body accessories (power steering, alternator, water pump, tensioner), Fbody Oil Pan assembly /w windage tray, pickup, Sensors -crank/tps/coilpack wiring harness/coolant temp sensor/IAC/cam
Take word for it buy new water pump and cooling fans, I have good luck with the rest of the parts used so far.
Of course you will need a good tuner, I finally can start the car without it popping do to the reversed wiring, but it starts and wants to die unless I keep my foot on the gas. It stills stumbles when the car idles down at a stop signs like it wants to die it usually stays running though.
I will try to minimize hi-jacking this thread but I'm going to throw a new LS2 shortblock with AFR 205s in my 69 camaro. However, I'm wanting to put a Carb. style intake on with a 4150 style TB and a chrome air cleaner on top. Then run a real clean fuel rail on each side. Also I will hide the coil packs and put some nice Chevrolet valve covers on her. I'm looking for the sbc look without sacrificing performance. I don't see anybody doing this. Will it not fit under the hood? My tuner tunes with SD so no MAF to worry about. Any insight? Thanks first gen guys!
Close up pic:
http://ep.yimg.com/ca/I/spideraccessories_2082_65448182
http://www.edelbrock.com/automotive_...ctor-ls1.shtml
The Edelbrock Victor JR EFI LS1 intake manifold. It is shorter than the Super Victor and should have a better shot at clearing the hood.
2) LS2 head bolts to be used? (I know the LS3/L92 4.065" head gaskets are needed)
