New L96 RPO...
Old Sep 9, 2010 | 09:41 AM
  #41
LS1MonteSS's Avatar
Originally Posted by RWC
The RPO code is MYD.
The TCM is inside the 6L90E transmission. That sounds like a great project that will keep you busy for some time and will be a good learning experience.
A small VVT cam would really wake it up if you're thinking in that direction.
Thanks for the info..
My reason for asking for the RPO code for my 6L90E was after I pulled the heat shield from the passenger side of the trany, I was expecting to see something starting with an "MY..." on the sticker but instead my started with "O" so I was a little concerned..
Any suggestions on the specks for a "small VVT cam"? I'm not trying to push the limits on this motor as I'm just starting out with the whole LS Swap thing.. And I really think that the VVT is the way GM is going with the motors.. I do have a LS3 Intake Manifold coming to me via "snail mail" I'm hopping to get it in this week. So that will up the HP a little..
By the way... I'm not 100% sure, but I think the intake manifold currently on my L96 has the same "MAP" sensor as required for a LS3 intake.. Once mine arrives in the mail, I will see how she fits.. Just passing this info on, as I have read alot of threads that other guys have done "Creative Engineering" to make an LS2 MAP sensor work on the LS3 intakes..
Old Sep 9, 2010 | 11:24 AM
  #42
RWC's Avatar
RWC
There are several that are working on them and some have VVT cams available now. Here is a thread that will give you an example of what you can expect. I am planning to get a small one for my Camaro next year.
http://www.camaro5.com/forums/showthread.php?t=101012
Old Sep 15, 2010 | 08:41 PM
  #43
LS1MonteSS's Avatar
I need some assistance.. I am looking for a replacement throttle body for the L96 I got.. The one I have seems to have been damaged.. the port for the wiring connection had something brake the tab off that keeps the plug connected.
I'm also trying to find a MAF Sensor.. The salvage yard I got the motor from can't seem to find the one that came with the motor.. with the motor being a 2010 L96 I'm not sure what will swap over..
Kevin
Old Sep 15, 2010 | 08:53 PM
  #44
HSV-GTS-300's Avatar
Originally Posted by LS1MonteSS
If it isn't raining when I get home I'll get the number and post it.
Has it stopped raining yet?
Old Sep 16, 2010 | 07:09 AM
  #45
LS1MonteSS's Avatar
DUDE, I am so sorry!! I thought I saw a post some where the next day and figured you caught it.. I will look over the block as much as I can as it is still a complete motor, and write all the numbers down for you and post it tonight!
Old Sep 16, 2010 | 07:20 AM
  #46
No drama. Thanks.
Block casting number should be here.
Old Sep 16, 2010 | 08:08 PM
  #47
Irish350's Avatar
Kevin, you could take this opportunity to go with a bigger-than-stock maf/tb now since youre getting both. Otherwise there are plenty of other stock options if youre keeping costs there low.
Old Sep 16, 2010 | 08:29 PM
  #48
LS1MonteSS's Avatar
Ok Guys... This is kind of off to what all I have seen for locating the casting numbers.. but I only found the numbers on the passenger side on the rear just opposite of the pics that GTS-300 posted.. 125827181
Again.. they were on the passenger side, rear... There was nothing on the drivers side at all.. is this something new for GM? it is a new motor.
Kevin
Old Sep 16, 2010 | 08:59 PM
  #49
LS1MonteSS's Avatar
I hear what your suggesting..
My thoughts were to get her in and sitting right in her new home.. Lay out the route for the air intake, radiator lines (oh yeah I scored a Be-Cool aluminum radiator with the EOC and TOC connections this past week), and the rest of the basic stuff then start pushing things a little..
I guess my big thing is tuning/ECM issues with adding anything new to the current combo.. I am going to have a learning curve for sure as I have not had to do any of that at all.. my other LS1 motor was a snap, I just hooked it all up, put a pump in a tank with gas and fired it up and she ran.. but then again that was all I did.. then I had to pack it all away and redeploy back to Iraq...
I really don't know anyone in my area that does anything with the new motors.. So I'm going solo on this..
That said...
So all I need is a MAF that will connect to the existing wiring? Any suggestions? The guy at Schram said he didn't see any "interchange" info on the MAF.. What about the ECM and a MAF that didn't come with the original motor combo? I know way too many questions!!
Kevin
Old Sep 16, 2010 | 09:10 PM
  #50
Irish350's Avatar
well tuning will definitely come into play (on my setup i knew from the getgo i wasnt going to do that, i already have a great local tuner), but i went with a 96mm tb and 100mm maf with my ls3 intake. I did grab a maf connection adapter from tsp with my maf (so it works with my 00 pcm). Although the computer will need to be tuned those types of mafs use stock parts so metering/tuning isnt bad if you have the experience/time/research into it (none of which i have)
Sorry i cant provide more as far as stock parts you could swap, but iirc the larger stock mafs are like 85mm (from most gen4 engine cars/trucks) and the tb will only get as large as 90mm, but there are many of them out there (cable or dbw driven)
Old Sep 16, 2010 | 09:52 PM
  #51
LS1MonteSS's Avatar
I think my TB (DBW) and MAP might work on the intake I'm waiting on to get here via the good ole postal system.. Long story!
I do want to get into the tuning.. and once I get the must have stuff (motor and trany mounts, LS radiator, new drive shaft, dash wiring to keep an eye on how the engine is doing) out of the way.. I was then going to get the HP Tuners or LS Edit.. But I tried to get some feed back on both of those on another thread but no real info.. I know I will need a tuner program to unlock the TU-TD in the trany and I still need to modify the ZO6 Corvette shifter i picked up to do the TU-TD.. I don't want flippers on my dang steering wheel...
If you get a chance check with your friend and see what he says about a MAF for my project..
Thanks
Kevin
Old Sep 22, 2010 | 09:17 PM
  #52
LS1MonteSS's Avatar
Well I got the LS3 Intake in today.. All looks fine with it.. Surprisingly the TB from my L96 Intake bolted right up and the MAP fit like a glove.
The only bummer is that the guy I got the intake from only sent me 8 of the 10 bolts.. I sent him an email in hopes of him sending me the other 2 bolts.. I can't complain really.. I got the new intake for $250 with injectors and fuel rails and a couple of lines. And NO the ones from my intake will not work, they are too short..
I still have to find a accessory bracket for the alt, it is in the way of the new intake sitting down all the way..
I ordered my motor mounts and trans mount kit today from BRP Hot Rods.. http://www.brphotrods.com
I'll let ya know how that goes..
Still nothing from Schram on the MAF sensor...
I need some assistance with all the connections on the LS3 intake.. Someone have a layout for all of that... I got the fuel connection.. what are the other ports for.. there is one on the back and two on the front. One below the MAP sensor location and one opposite that on the other side.
Old Sep 22, 2010 | 09:44 PM
  #53
Kevin
Thanks Kevin.
Are you sure its a 9 digit number and not an 8 digit like usual?
Old Sep 23, 2010 | 05:25 AM
  #54
Did the valley cover under the intake have a 3/8" tube sticking out the front like this?
or does it have a lifter oil control manifold like this
Old Sep 23, 2010 | 06:49 AM
  #55
LS1MonteSS's Avatar
Originally Posted by HSV-GTS-300
Thanks Kevin.
If there is another place to find you that number let me know! I will look at them again as I had my son read them off.. I did find it odd that the numbers weren't located where they usually are..
Old Sep 23, 2010 | 06:55 AM
  #56
LS1MonteSS's Avatar
No 3/8" tube in the front, just the boss for the sensor in the rear like your first picture.
In that first picture I see numbers stamped on the left on the block, just infront of the head.. are those the same as what should be in the rear on the drivers side?
Old Sep 23, 2010 | 07:05 AM
  #57
I don't know where the location is on a cast iron block.
The number you gave is the type of number I'd expect to see, the sequence just has one too many digits.
In that first picture I cee numbers stamped on the left on the block, just infront of the head.. are those the same as what should be in the rear on the drivers side?
No what you are seeing there is the unique engine number.
Old Sep 23, 2010 | 07:08 AM
  #58
PCV System.
Hose A-B
Fresh Air Supply Line.
From Air Intake Pipe to Front Right Valve Cover.
(Supplies fresh filtered air to the PCV system)
Hose C-D
Foul Air Line.
From Rear Left Valve Cover to Front Right Intake Manifold.
(Supplies foul oily air from the PCV orifice in the valve cover to the intake manifold for consumption by the engine)
Old Sep 23, 2010 | 07:10 AM
  #59
EVAP System.
Hose E-F
Gas Vapour Supply Line.
From Vapour Canister on Fuel Tank to EVAP emission solenoid valve.
(Supplies gas vapour to the EVAP system)
EVAP System.
Hose G-H
Gas Vapour Discharge Line.
From EVAP emission solenoid valve to Front Left Intake Manifold.
(Supplies gas vapour from the EVAP system to the Intake Manifold for Consumption by the Engine)
Old Sep 23, 2010 | 07:19 AM
  #60
Rear of Intake Manifold.
The red removable cap is the vacuum port for brakes.
Just to it's right (the small anchor looking removable plug) is a vacuum port for accessories.
