LS7 Valve Size Question
Old Jan 12, 2010 | 04:11 PM
BgBoost1's Avatar
Default LS7 Valve Size Question
LS7 Cylinder Head: I need to know the Overall Length and the tip length of the Intake and Exhaust Valves that come from the factory.
Does anyone have this information?
Thanks in advance!
BgBoost1
Old Jan 13, 2010 | 03:53 PM
BgBoost1's Avatar
Anyone?
Old Jan 20, 2010 | 06:06 PM
DB Z28's Avatar
Intake 5.1550
Exhaust 5.2525
Old Jan 20, 2010 | 07:30 PM
G Engines's Avatar
Intake are 4.900 with a .160 tip
Exhaust are 4.923 with a .160 tip
Old Jan 20, 2010 | 07:41 PM
Shawn @ VA Speed's Avatar
Might want ot recheck your measurements-those are 15deg head measurements not 12 deg
Old Jan 25, 2010 | 06:17 PM
BgBoost1's Avatar
Originally Posted by DB Z28
Intake 5.1550
Exhaust 5.2525
THANK YOU. I bought 2 new valves to measure them and took them to a machinist and measured 5.230 for Exhaust and 5.130 for Intake so at least I know that I am close!
Old Jan 25, 2010 | 06:24 PM
rsz288's Avatar
You probably are aware, but just in case FYI once the valves are installed and the lash cap on the intake, they sit at the same tip height.
Old Jan 27, 2010 | 03:15 PM
BgBoost1's Avatar
I knew that....that is why I didn't trust the master GM Manual and Jason at Katech when they both told me that the intake and exhaust valves were the exact same length.
Thanks!
Old Jan 27, 2010 | 03:54 PM
rsz288's Avatar
You are dead right there. Same installed height but not same length.
