Looking to build 454lsx
Old Jan 17, 2010 | 12:54 PM
delphigto's Avatar
What block did you use for a 4.2 bore?
Old Jan 17, 2010 | 01:39 PM
03supercobra's Avatar
I am using the LSX block.
Old Jan 25, 2010 | 05:35 PM
briannutter's Avatar
There are a number of builders on this forum that have done long lasting 454 standard deck LS engines (including GM). "Rod ratio" is never more important has having proper minimum ring land thickness for a given application. The main thing is to have a properly designed piston and good sleeve length. I agree that cubes aren't everything, but I'd pick more than less if N20/Boost isn't in the equation....if for nothing less than for valvetrain stability.
Old Jan 26, 2010 | 08:18 PM
delphigto's Avatar
Does gm sell a short block? I think I might go with a 4.185 inch bore 4.00 stroke. No nitrous or blower. Im wanting to go with ported l92s or ls7 for heads. Ive also thought about calling erl I have a ls2 block sitting here.
Old Jan 26, 2010 | 08:39 PM
LSX67RS/SS's Avatar
Is there a problem going with a 4.25 bore on the LSX block? I'd like to keep the stroke as short as possible.
Old Jan 26, 2010 | 08:57 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've built 4.200" bore LSx blocks, but that's about as far as I've seen people running. 4.200 bore 4.100 stroke builds a 454. I'm putting my 454 LS7 together starting tomorrow. I'll post pics for you guys. I have all the components in stock to build a LSx 454 and access to a block someone bought & then decided not to use. If you want a quote on a assembled short-block I'd be happy to put one together for you, I bet we can make you one at a pretty good price!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 26, 2010 | 09:29 PM
LSX67RS/SS's Avatar
Thanks Jason,
I've called TSP several times for cam questions and intake, appreciate the help and knowledge. Looking to order a cam, heads and possibly an intake from TSP. i'll follow your lead and go from there. i,m still installing the 4 link so i have 6 months before i need engine hardware.
For some reason i thought i saw someone boring these out to 4.25" i could've been mistaken.
Please post pictures and data, i'll follow your lead.
Tony
Old Jan 27, 2010 | 05:28 PM
The bore spacing on these blocks is too low to go 4.250. plenty of material on the major and minor thrust -but none in between. Had a guy with an aftermarket sbc START at 4.250 because he read their ad and it didn't make it off the dyno. HUGE BLACK SCORE in the siamese area all the way up and down. He was screwed...new block and pistons necessary...started at 4.185 next time around
Old Jan 27, 2010 | 08:11 PM
Is this the real brian nutter posting? LOL
__________________
Jason
2005 Twin Turbo C6
Old Jan 28, 2010 | 10:41 AM
delphigto's Avatar
Pm sent
Old Jan 30, 2010 | 05:49 PM
delphigto's Avatar
Has anyone had any problems erl? Think Im going to do a 440 with my ls2. I did a search and found https://ls1tech.com/forums/ls1tech-s...rformance.html
Old Feb 17, 2010 | 12:46 PM
  #32
gto_ua's Avatar
So what is the max bore in GM 454 LSX then? I took one damaged with 4.185 bore with minor cylinder wall scratches... How far can I hone it (N/A, not boost, no nitrous)?
4.25 - impossible?
Old Feb 17, 2010 | 04:41 PM
  #33
delphigto's Avatar
4.2 is as far as you want to go.
