Looking to build 454lsx
-Clayton
-Clayton
-Clayton
, remember RPM's are your friend. FWIW Eric is the one who told me to stay away from the 4.125 crank when building a nitrous motor. Couple things here:
You never compared to one to the other at the track so you don't have any results thats says a smaller engine makes a car quicker.
You made more power because the other engine was built wrong if it was eating oil.
Erik does not recommend a power add when the piston is compromised, not directly due to the stroke of the crank. The piston gets compromised on the longer stroke.
How does that statement make sense? Maybe im not reading it clearly?
Haha your kinda jumpin on me off the bat aren't you? I was just providing my info, hopefully to help this guy in his decision making process.
Im saying in my case my new setup made more power, there were alot of variables along with oil burning. I didn't setup the last motor that was in it.
From my understanding you can't run a good nitrous piston, ring-land design and wrist-pin location, with that long of a stroke on the iron blocks.
I was not jumping on you, just correcting a few things you said.Someone reading what you had posted might get mislead.
Yes the sleeve length is not of such that you can run the longer stroke without compromising the piston.
But, increased stroke does cause more side loading on the pistons, and you always want to use the longest rod possible. Maybe thats just my opinion
