PRC dual valve spring broke
Old Jan 24, 2010 | 11:13 AM
tomhGTO's Avatar
Default PRC dual valve spring broke
So i broke a PRC dual valve spring in a l92 head. End result was a Manley intake valve stem snapped.
Not sure if I can order just one valve spring from PRC but if one goes would it be highly recommended to replace all of them? Springs have about 15k - 20k miles on them.
Same w/ the valve. It was a Manley intake valve, are there any vendors that would sell just one or are you stuck purchasing all 8?
Old Jan 24, 2010 | 03:05 PM
mike c.'s Avatar
WOW. is your cam hard on the springs? I would replace all of them and not just one. Then you have a full fresh set. I ran comp 921's in the past and run them in my l92's. Never had one go yet.
Old Jan 24, 2010 | 03:08 PM
badss_02's Avatar
It's a good practice to replace those springs or at least have them checked every 10k... Especially under higher lift.
Old Jan 24, 2010 | 03:39 PM
sixt9er's Avatar
Damn! I have a set of Manley's going in a set of L92 heads...How did you manage to break off a valve stem?
Old Jan 24, 2010 | 04:05 PM
vettenuts's Avatar
Are you sure the valve spring went and failed the valve or is it the other way around? Not sure what your end results are but you should have the guide checked on that valve. Single valves can be purchased but make sure to explore why the failure occurred.
Old Jan 25, 2010 | 12:30 AM
tomhGTO's Avatar
lift is .6 so the PRCs should take it fine. its an FI motor w/ 11 PSI. I was cruising in 6th at 65 mph when the spring went.
Old Jan 25, 2010 | 12:33 AM
tomhGTO's Avatar
Originally Posted by vettenuts
Are you sure the valve spring went and failed the valve or is it the other way around? Not sure what your end results are buy you should have the guide checked on that valve. Single valves can be purchased but make sure to explore why the failure occurred.
I found the tip of the valve guide in the intake manifold. Lucked out that it didnt go into the piston or make it to a turbo. I guess that means im buying a new head if the valve guide is cracked off though.
Old Jan 25, 2010 | 12:34 AM
tomhGTO's Avatar
Valve spring broke and caused the valve to break. I dont think it was an issue w/ the valve. Im going to replace it with another manley valve.
Old Jan 25, 2010 | 01:43 AM
01wssick's Avatar
Tom- I sent you a pm.
Old Jan 25, 2010 | 12:07 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I might have a few of the old PRC springs left we could get you. We've switched to a all new spring now so I don't have much of the old stuff left. The new spring is a ground up redesign so it requires a new spring/retainer combo instead of just swapping to the new spring.
What color is the spring? Gold or Silver?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 25, 2010 | 05:45 PM
tomhGTO's Avatar
appreciate the help guys but looking to replace the springs all together. decided to go with some PSI valve springs. looking at some of their 1500 series.
Old Jan 26, 2010 | 10:43 PM
Gray86hatch's Avatar
Do you have hollow stem stuff and Ti retainers??
I have been told that the stem to valve dia is huge and this requires getting as much weight as possible out of the valve side.
I have a set of hollows comming for mine along with PAC 1521 and Ti retainers. Not cheap
Tim
Old Jan 27, 2010 | 12:08 AM
tomhGTO's Avatar
Tim
going with some comp valve springs that are actually made by PSI. They are the 1500s w/ the nitriding. will be using Ti retainers.
stock exhaust valves and manley intakes, not hollow.
Old Jan 27, 2010 | 06:22 AM
Busted Knuckles's Avatar
Don't toss the head yet, guides can be repaired in most cases.
Old Jan 27, 2010 | 09:10 AM
SS Enforcer's Avatar
I know of a l92 headed 6.0l that got lunched due to a valve guide breaking recently. The forensics indicated it slowly came loose over a period of a few months and finally cracked which sent the valve wobling and kissing a piston then bang. First inspection looked like a broken duel valve spring until closer inspection revealed a problem that had developed over time .
cheers
Old Jan 28, 2010 | 05:32 PM
bozzhawg's Avatar
So should you stay with the solid valves or hollow?
Is there any real advantage to usig hollow valves?
Old Jan 28, 2010 | 05:57 PM
I got my hollows yesterday. Will get them weighed up this weekend.
Weight is killer with this big of a valve.
Tim
Old Jan 29, 2010 | 01:06 AM
Sid447's Avatar
Smile
Which leads to the question,
Do Manley and other well known valve-train manufacturers offer hollow valves?
If not, why not?
As long as you are using the best quality springs available and changing them at the required interval recommended for hi-lift application the valves will stay where they are supposed to be.
Old Jan 29, 2010 | 07:44 AM
Manley is a entry level valve. Others make hollow valves. Fererra does. GM, REV
You can put the best springs in the world on it but the more weight you have is going to cause issues. Lighter is better.
Tim
Old Jan 29, 2010 | 09:53 AM
1.8t's Avatar
While that is true, there are plenty of people out there running stainless valves(heavy) and rev'ing their hydraulic roller setups to ~7200rpm with a quality valve spring and having no float issues. Will a lighter setup be easier on parts, last longer, and allow for a spring with better harmonics? Yes, but that doesn't mean you can't go the other route as well.
