Quench for 4.125", 16 psi?
However, on a boosted engine, some people have claimed that larger distances (.050-.100") actually help make more power.
Anyone have any comments as to why this might or might not be true?
With a super/turbocharged engine, the cylinders are much more densely packed with fuel and air, and the combustion is a lot quicker. Imagine lighting a brush fire in the desert, versus a dense forest. Which fire speads quicker?
I would guess, that the crevices in the quench area cause peak pressures to be a lot higher than the rest of the chamber, probably inducing detonation. That could probably even explain why the Hemi chamber is the standard in T/F and T/A classes, as there is basically no quench area at all.
I'm probably wrong though. lol
I would assume these things would apply to the LS engines.....
I did my 403 Procharged engine at .041" quench because I didn't want to spend for special thickness H.G.'s and it was fine at 14-15 psi - pump gas and meth - when I tore it down. It didn't like more than 16* WOT.
Would have been interesting to play with the quench (open it up) and run it again to see if it would tolerate more timing.
