6.2 liter Question.
Old Feb 2, 2010 | 06:35 AM
e-racer-ls-1's Avatar
Question 6.2 liter Question.
I can get a L-92 motor on the cheap,cheap.Can they be bored .030 over?The liner looks very thin.It dropped a valve and nicked the wall slightly.Thanks in advance...
Old Feb 2, 2010 | 06:53 AM
87silverbullet's Avatar
I don't think .030 is possible. You can go .010 to .015 if I remember right.
Old Feb 2, 2010 | 09:10 AM
t/a98's Avatar
i believe some have, its getting very very close at that point though.. you have to get it tested because it may not have enough wall thickness to, but at the same time it may.
ive read alot of threads on this so a search may be helpful, alot of people want to put ls7 heads on this block but they have a 4.1 min bore.
you could always sleeve it but then your cheap idea will be thrown out the window...
Old Feb 2, 2010 | 04:35 PM
Default Thanks.
The guy I am getting it from says the walls did not get touched when the valve dropped.Went through the top of the piston.We shall see!!
Old Feb 6, 2010 | 11:46 PM
IHEARTLS1's Avatar
hahaha ur joking right?
Old Feb 7, 2010 | 05:23 AM
redhotev's Avatar
Talk to Texas Speed they have bored some to 4.100. The GM performance book says you can bore +.030. I am going to bore one to 4.070.
