pics of LS7 442 stroker build my 2010 camaro
Motor should be fired next week and on the dyno.
Build specs:
LS7 block
forged Wiseco pistons
forged rods and stroker crank (442ci)
Livernoise ported heads (w/valve job and new valves)
921 comp springs
hardened pushrods
LSX-R 102MM intake
60Lb injectors
comp cam
new timing gear and chain
new lifters
roller rockers
Kooks LT headers
full exhaust
New Era CAI
oil catch can
Fidenza twin disc clutch
hurst short throw shifter
Progressive Zex nitrous system with independant fuel system
![](http://i614.photobucket.com/albums/tt227/mark_pharis/IMG_0387.jpg)
![](http://i614.photobucket.com/albums/tt227/mark_pharis/IMG_0380.jpg)
Build specs:
LS7 block
921 comp springs
hardened pushrods
LSX-R 102MM intake
60Lb injectors
comp cam
new lifters
roller rockers
Kooks LT headers
full exhaust
New Era CAI
oil catch can
![](http://i614.photobucket.com/albums/tt227/mark_pharis/IMG_0377.jpg)
yeah this motor is a pice of cake from the top. didn't even have to take the hood off.. A lot of companies are dropping the whole cradle out of these 5th gens??? I don't know why??
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Mark:
Your ride sounds like it will be a blast to drive. I am doing a similar engine build for a G8 and I am curious as to the compresssion ratio you are gettting and which Wiseco piston you are using.
Thanks
Thanks
I kept my compression ratio ~11.15:1 because I want it to be very streetable and because I will be running a 200 progressive shot on it. I am not sure the exact piston without looking at the box. It is their new coated pistons. Piston choices a very limited for the ls7442 builds unless you go custom.
Thanks for the feedback on the pistons you are using. If you happen to see the box and remember the part number, I would lke to get it from you. When I look at the Wiseco catalog for the 4.1 and 4.125 stoke pistons with the 4.125 bore, (assuming the 70cc combustin chambers), I only see choices for 12.2 and 10.0 compression ratios. I would like to get the 11.1 or so that you are getting.
um... how safe is it to spray a 442 ls7 block? i guess a lot of timing is going to be pulled when activated??? if i had the money right now i would be doing the same block/cubes not sure on how much nitrous can be used though too many pple on here say should/should not be done. who's building the motor?
+1 on the no bag'ig
+1 on the no bag'ig
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
