370 help
Old Feb 28, 2010 | 08:58 PM
cbr600rx7's Avatar
Default 370 help
Just a few questions on a 370 build. Sorry for the lack of info as this is a used motor.
Forged 3.622 stroke x 4.030 bore
ARP Main studs
ARP Head studs
Eagle H beam rods, with ARP bolts
Stock crank
Diamond -2cc flat top pistons
Steel top nitrous rings
LS6 patriot 2.08/1.6 64cc heads
Thunder racing T Rex Cam
Double Roller Chain
almost 12.0:1 compression
110LSA with a 242/248 duration
Assembled by ( Tom - Bad LS1 )
First: of all what kind of power should i be expecting to see out of it with a built 4L60 and 12 bolt.
Second: what kind of intake set up should i be looking into. I know the FAST 90/92 is probaly the way to go, or can we get away with running a LS6.
Finaly:Thank you Jeff for all your help.
Old Mar 1, 2010 | 10:34 AM
cbr600rx7's Avatar
Maybe I should explain what I am trying to do. I would like to make 420-450 with pump gas on motor. Once we get all the bugs out of the motor I want to build a hard-line plate kit for a 150-200 shot. Would I have any problems accomplishing this with this set up.
Old Mar 1, 2010 | 09:06 PM
cbr600rx7's Avatar
Any body???
Old Mar 2, 2010 | 11:32 AM
cbr600rx7's Avatar
3 days and 60 views no post????
