What the hell is this part, and what does it do?
Old Mar 20, 2010 | 09:33 AM
quadman's Avatar
Default What the hell is this part, and what does it do?
2006 GTO LS2 oil pan. It is hitting one of the ARP studs. Some say it is a oil pressure relief valve. Others say it is oil filter bypass valve.
Is it safe to remove it and plug the hole?
Old Mar 20, 2010 | 10:05 AM
edcmat-l1's Avatar
Looks like an oil filter bypass. I don't know if I'd plug it. Make sure your ARP studs are in all the way. How much clearance? Can you grind the stud down some?
Old Mar 20, 2010 | 11:09 AM
quadman's Avatar
Thanks, Ed. Yeah, the studs are in all the way. In actuality, the stud hits withOUT the pan gasket in place. With the gasket in place, we have clearance, but in our "infinite wisdom", we wanted to be sure, so we tried to grind it a little. That's when it self-destructed........lol.
I am still wondering if it would be ok just to leave it out and plug the hole in the pan.
Old Mar 20, 2010 | 12:21 PM
cam's Avatar
cam
F-body oil pans do not have the oil filter bypass iirc and they work out fine. Trucks, GTO's have them so when guys swap out truck engines with F-boy pans it seems to work fine. Just what i've seen and what im going to do also
Old Mar 21, 2010 | 02:23 AM
rsz288's Avatar
Its the DOD/AFM pressure regulator. Some have plugged it or blocked off the gallery it vents to chase additional oil pressure. Really only necessary with AFM and higher vol oil pump.
