Valves cover problem !??
Old Mar 23, 2010 | 09:19 PM
PwrdbyLS1's Avatar
Default Valves cover problem !??
I currently building a LY6 engine with L92 head, etc.. in my 99 Camaro. But when I install the valves covers(99 camaro) in with the rockers install, the passenger side cover hit the rockers. The deflector thing for I think vaccum hit the rockers. I have the LY6 covers but it dont have the vaccum tube. Is this will cause vaccum problem if I take the LY6 cover instead of my 99 cover?? Here's 2 pics of the covers...
Upper one is LY6 and bottom one is 99 camaro
If it cause no problem I will use the LY6 covers.
Thanks for your hints!
Old Mar 24, 2010 | 04:58 AM
Petraszewsky's Avatar
Absolutely no problem if you use the newer style cover...Or you could trim the baffles out of the older style cover...either way good to go...
Old Mar 24, 2010 | 05:10 AM
vettenuts's Avatar
I had to remove the internal baffles and the bosses on my valve covers to clear my rockers. I would modify your 99 covers to clear because the tube is part of the PCV system and needs to be connected.
Old Mar 24, 2010 | 11:37 AM
The newer style just has the internal baffles and a single tube rather than external baffles and 2 tubes..Either way you're fine...
Old Mar 24, 2010 | 05:40 PM
PwrdbyLS1's Avatar
But if I trim the baffle in the 99 cover, the tube will be in contact with more oil. Do the engine can suck more oil from the pcv system?
If I install the LY6 one, I can block the passenger pcv tube and only run the driver side? Can I delete all the pcv system?
Thanks!
Old Mar 25, 2010 | 10:29 AM
Don't delete the whole system but on the newer LS2 the drivers side is blocked off on cars..( trucks still use it) But it will function perfectly like normal with just the pass side tube used...
