My VA Speed Engine Build
Car has some left in it too. It was 10.9 A/F from the 1/8th to the 1/4. Gotta figure out why the motor runs rich. It runs 11.8-12.0 all through 3rd on motor too. I'm commanding 12.88. ??
Need to tweak some on the shift points and get the a/f a little more leaned out and I should be able to get in the 9.6-9.7 range I think. The 9.98 run was on 60% hit and 1 second ramp.
This is on a 150 shot.
http://www.youtube.com/watch?v=iAGklFdcviQ
Good runs and tons of fun... Oh and I shoulda taken that chick out for a ride around the parking lot, I think I would of gotten at least a BJ...LMAO In talking with Magnum on the GTO board who is the current fastest with nitrous cutting 1.3x 60' he says the key is the ramp rate on the launch. He said you should not spray more then 5% on the initial hit, but ramp in the full shot by .5 sec. He said the slightest tire spin destroys your 60' and of his thousands of track passes this has been the best way.
So with Crandall out where are you going to race now? Or do you plan on putting in a cage? If you do I can get you in touch with the guy in florida who is shipping me mine. it is not to expensive, just have to pay someone to put it in when it gets here.
What I need to do is figure out why the car is running rich. It's 11.8s-12.0s on motor too. Even though I'm commanding 12.88. Also I have to figure out how to setup the shifts because it shifts lazy on the jug.
If I can just figure out how to get the commanded a/f to equal actual this thing will really scoot.
If it's down on the motor, it'll be down on the jug too.
