First LSX stroker build....HELP!
Old Apr 2, 2010 | 08:59 PM
bcartman_2's Avatar
Default First LSX stroker build....HELP!
Ok, so I am gearing up for my firs LSX motor build and I am sure to have lots of questions. For starters I will tell you what I want to do; I want to build an LSX bowtie block bored to 4.18 with an Eagle forged crank with a 4.1 stroke. Eagle 6.125 rods and 11:1 diamond pistons will finish off the bottom end. I want to go with PRC LS7 285cc heads with whatever mean cam I find….I haven’t gotten that far yet. And on the top a FAST intake. I know my list isn’t complete but you see where I am going. What is a safe hope for HP? If in the future I want more would this take 5-8psi boost (with meth)? Are there any recommended changes from the guys who have done this? Am I going in the right direction? Are there any books you recommend for me to get more info?
Old Apr 2, 2010 | 09:21 PM
ChucksZ06's Avatar
You will be fine with that combo.
Old Apr 2, 2010 | 09:33 PM
LS6427's Avatar
So you're building a 450 cubic inch monster. How much cash do you have to spend on this whole project?
Old Apr 3, 2010 | 10:27 AM
Azrael's Avatar
Outstanding question, as it most likely be more than you wanted (or thought) you would spend. We found with our LSX based 454 (4.187 bore with a 4.125 stroke) that it was the little things that added up quickly.
What are your goals? How do you intend for the big guy up front to transfer all of that terrible power to the ground? Is your driveline ready and is the rest of your car ready? What are you doing for exhaust? Clearance for that exhaust (k-member, motor mounts) and how will it fit with what you may currently have on the car? What are you doing for fueling the monster? What about vacuum... Crankcase venting... Intake routing... Tuning and electronics (Big Stuff 3/PCM tuning, plug heat range, custom plug wires, etc)... etc, etc, etc...
Yeah it adds up quick...
Old Apr 3, 2010 | 01:26 PM
supermouse4's Avatar
It sounds like that this is going to be a powerful and amazing build of a 450+ inch LSX motor. How much power are you going to build with this motor and what vehicle will it go into?
Did you ever think of buying an LSX 454 instead of having to worry about machining, buying parts, balancing, and all the other factors about building? Not trying to persuade a direction one way or another. Good luck in your build.
Old Apr 3, 2010 | 02:30 PM
99T/ATIME's Avatar
Thats an idea, but just be aware that the GMPP LSX 454 is now coming with an 8-bolt LSA Crank pattern.....If the car is manual, you are SOL with flywheel/clutch options.....Auto is a different story, I believe GMPP offers an 8-bolt flex-plate for it.
Old Apr 3, 2010 | 11:04 PM
bcartman_2's Avatar
Ok so I am the guy building a motor with no car.... I am looking into an F-body or a GTO, I dont think a vette will put up with my abuse.. I am looking at $12k for the motor and annother $8k for the install and all of the needed upgrades for the power. Not to mention $15-20k for a car. What are your takes on F vs. GTO?
Old Apr 3, 2010 | 11:07 PM
abcdefg's Avatar
f= light weight
Old Apr 4, 2010 | 11:10 PM
Soul TKR's Avatar
so what's the mathematical equation you guys are using to figure out CI's?
Old Apr 5, 2010 | 03:05 AM
Azrael's Avatar
There are a couple different equations, the one I use most is:
Pi x (1/2 bore x 1/2 bore) x stroke x number of cylinders = displacement.
Old Apr 5, 2010 | 11:07 AM
Stang's Bane's Avatar
Not enough money.
Why do you think a Vette won't put up with it??
Old Apr 5, 2010 | 11:18 AM
Antler's Avatar
If your building a one-off 440+ inch Motor that 12k budget is gonna be spent quick
Old Apr 6, 2010 | 12:39 AM
Soul TKR's Avatar
i see... thanks man!
however, after a quick google search i found an online calculator where you just plug in the bore/stroke and it gives you the CI's without all the math
Old Apr 7, 2010 | 09:53 AM
1Hotbird's Avatar
Thought you might like some reading on my LSX 454 build a few years back.
I was dealing with MPH Motorsports in Florida I'm not sure they are still around?
Looks like they might of moved to IL ????
https://ls1tech.com/forums/generatio...-they-way.html
Also The car is for sale if you want to buy one done, then maybe upgrade the top end!! link is in my sig below
