Comp 227/235 LSL Cam
Here's the full setup: LY6 engine 6.0L iron block(stock short block), L92 hand ported heads(340 cfm @.600) milled .035, LS3 ported intake, 227/235 cam, 85mm MAF, 1 3/4 headers, catted 3" Y pipe, 3" cutout, magnaflow catback, underdrive pulley, textralia OZ700 z grip clutch, 3" driveshaft, Moser 9" & 4.11 gears.
Static comp is 10:1, timing at 31.5°, A/F around 12.8
462.5 rwhp @ 6500 & 420lbs @ 5000 (SAE corrected)
Higher run is open cutout, lower is close. Tell me what you think about my numbers.
The dyno is a Dynocom, but I will do a other run on a Mustang dyno in maybe a month to see the difference.
Here's is a little video with open cutout. Enjoy!
http://www.youtube.com/watch?v=3MTINkxbuzQ
Build is retaining VVT on a stock bottom end 6.2L, stock L92 heads, 222/230 EPS cam, 1 3/4" LT's, 2.5" y and single 3", LS3 intake ( soon to be ported ) ported TB, UD pulley, 85mm MAF, tex z grip, 3.73
Pretty similar... Hope I get decent numbers out of it.
BTW any idea what the difference is between a Mustang dyno and a Dynocom? Which is more generous?
LSWNDR - You pretty BIG cam! must be insane to drive with those numbers !
cam - Your build is pretty interesting, you should pick up numbers similar to me. Keep us update.
Petraszewsky - Post your numbers and setup when you got it !
