are harlands adjustable?
Old Apr 27, 2010 | 07:38 PM
BigDB's Avatar
Default are harlands adjustable?
Are harland sharp LS rockers adjustable? I had a motor built and just cranked it up so its the first time the lifters have had oil in em and I want to know if the rockers are adjustable or not to set the valve lash. Valvetrain isnt noisey but didnt know if maybe they were tight.
Old Apr 27, 2010 | 09:27 PM
SOMbitch's Avatar
They make an adjustable rocker for Gen III heads but I don't believe they do on Gen IV heads.
Lifter preload is set by pushrod length with the non adjustables most people run. Just need a $20 PR checker to measure PR length and add in required lifter preload. Let me know if you need more info on how to measure and I can help out.
Who did your motor BTW. I used to live there and am familiar with a few of the shops that way....
Old Apr 27, 2010 | 10:47 PM
BigDB's Avatar
Mayhem Motorsport did, not to pleased but its what I got. Prelode should have been checked as the valve angle was changed with my heads and a shorter pushrod was required. I just didnt know if the harlands were adjustable, never saw em b4 they went on
Old Apr 28, 2010 | 12:57 AM
SOMbitch's Avatar
If they are quiet I think you are OK. I have never had any personal experince with them but they have been at a while so I gues they should be decent...
Having said that RPM in Garner would be my first choice in the Raleigh area. Those guys have helped me out a couple times and flat out know there ****. Just stop by there shop sometimes and check out what they are doing. Always 2-3 NASTY builds going on...
Old Apr 28, 2010 | 06:41 AM
BigDB's Avatar
ya iv delt alot with RPM, at the time they didnt want to build an engine so I had Mayhem do it. RPM will be doin the dyno thou
Old Apr 28, 2010 | 03:03 PM
SOMbitch's Avatar
Yeah Ryan tuned my car too. I am getting ready to port my FAST and do a bigger MAF and lid and will be back up there for a tune tweak soon if nothing else pops up..
Not sure but I always thought somebody did RPM's shortbocks and they finished them off but I could very easily be wrong.
Any way tell Jason and Ryan up there SOMbitch said "hi" and good luck with your setup
Old Apr 28, 2010 | 11:23 PM
BigDB's Avatar
Will do man and thanks for the help
